| Product(s): | HAMMER | ||
| Version(s): | 10.02.01.06 | ||
| Area: | Installation |
The new CONNECT Edition Update 2 release of HAMMER (build 10.02.01.06) introduces numerous improvements and features to help you be more successful.
Stability enhancements and fixes to reported issues
Support for AutoCAD 2020 and ArcGIS 10.7 has been added in this release.
Compatible Operating Systems
Windows 10 (32-bit or 64-bit)
 Windows 8 (32-bit or 64-bit)
 Windows 7 (32-bit or 64-bit)
Compatible Platforms
The Standalone version does not require any CAD or GIS software to work. However, it can be integrated with the following platforms:
MicroStation V8i SELECTseries 4 (Some earlier versions may work as well. MicroStation CONNECT Edition integration is not yet supported with this release.)
 AutoCAD 2020, 2019, or 2018
 ArcGIS 10.7
HAMMER are now compatible with ProjectWise build 10.00.02.320
Model Compatibility
Models saved in the updated release of HAMMER (version 10.02.01.XX) can be opened in the initial CONNECT Edition Update 2 release (version 10.02.00.XX).
See: Model backward / forward compatibility
As with all new versions, this release includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
Downloading OpenFlows / Hydraulics and Hydrology Software
Cumulative patch set information
Set up notifications for new versions and patch set releases
| Original Author: | Scott Kampa |
