| Product(s): | WaterGEMS, WaterCAD, HAMMER |
| Version(s): | V8i, CONNECT Edition |
How can I use patterns to change the pump speed over time (or turn it on/off based on time), or reservoir hydraulic grade over time?
Each reservoir and pump can have its own pattern assigned to it.
Steps to create and assign a reservoir pattern:
Note: this pattern only applies to an Extended Period Simulation (EPS).
To change the hydraulic grade over time during a transient simulation in HAMMER, use the periodic head-flow element: Modeling a change in HGL or flow during a transient simulation
A pump pattern can be used to turn a pump on/off over time (simpler than creating time-based logical controls), or change the speed of the pump over time (for example if you already know how the pump ramps up.down over time)
Steps to create and assign a pump pattern:
Note: this pattern only applies to the speed of the pump during an Extended Period Simulation (EPS).
To change the pump speed over time during a transient simulation, use the pump's transient Operating Rule.
You can also assign patterns using FlexTables. This will allow you to sort by zone or pump station.
Customizing FlexTables for viewing and reporting data -- Moving, adding, and removing columns
