| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | V8i, CONNECT Edition |
| Area: | Output and Reporting |
An error message occurs when printing reports and flex tables:
"An error occurred during printing a document"
In at least one case the issue was the file path was too long for the model, so it had issues printing. The solution was to move the model files to a location with a shorter path like your desktop or documents folder.
It is recommended to avoid long using a very deep folder location (with many sub-folders) and to save the model to a shorter file path.
Error when opening model files: The specified path, file name, or both are too long.
