Product(s): | WaterGEMS, WaterCAD |
Version(s): | 10.XX.XX.XX, 08.11.XX.XX |
Area: | Installation |
When opening the WaterGEMS for AutoCAD shortcut, the following errors are encountered:
"No Profile name Exists: WaterGEMS. Will create Profile with default settings"
"Cannot find the specified drawing file. Please verify that the file exists."
"Arquivos.scr" Can't find file."
This may be due to a problem with the target path in the shortcut. Special characters or extra spaces in the translation of "C:\Program files\ ..." may be cause the path to be unrecognized. To resolve this, first delete both the desktop and start menu shortcuts, then run the "Integrate WaterGEMS with AutoCAD...." shortcut, under the WaterGEMS start menu folder.
If the same error is still encountered, wait until AutoCAD opens, then go to OPTIONS, the "profile" tab and set the WaterGEMS profile to current.
