| Applies To | ||
| Product(s): | WaterGEMS, WaterCAD | |
| Version(s): | 07.xx.xx.xx | |
| Area: | Other | |
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
When trying to open a open a project file for WaterCAD 7 or WaterGEMS 3.0 you get the following error message below:
CWaterProjectFactory::DataConnectionFactory
HJetDataConnectionFactory : Failed CJetDataCollection::UserCount
Unable to open roster
With the older versions of WaterCAD and WaterGEMS, like WaterCAD V7, there used to be a file path character limit of ~110. This is no longer an issue with later versions of the application.
Either place a copy of the .WCD and .MDB files for the project on your desktop to open the project and work with it there or shorten the file path location on your server where the project files are located. If you choose the former option you can always copy the files back to the server location once you are done working with them from your desktop.
