| Product(s): | WaterGEMS, WaterCAD |
| Version(s): | 10.02.02.06 |
| Area: | Output and Reporting |
Is it possible to customize or modify the appearance of the Flushing Field report?
Some examples:
- The field crew does not speak English and a custom translated version of the headings is desired, for words such as "measured flow", "predicted pressure", "water quality", etc. (Enhancement # 1056288)
- A maximum of 13 rows are available to show valve operations. How can this be expanded in cases where a flushing event requires more than 13 operations? (screenshot below)
As of version 10.02.02.06, the appearance of the Field Report cannot be directly modified. It was configured in such a way that it should work well for almost all cases. However, the report can be exported and modified externally in cases where the default appearance is not sufficient.
- Click the export button at the top-right corner of the print preview, choose to export to Excel format, then modify as needed in Excel before printing.
- You can also export the Flushing Area Summary Table in the latest release.
See more: Exporting Flushing results to Excel or other standard format
Flushing operators report graphic or background is blurry in the print preview
