Applies To | |||
Product(s): | WaterCAD, WaterGEMS, HAMMER | ||
Version(s): | 08.11.XX.XX, 10.XX.XX.XX | ||
Area: | Other | ||
Original Author: | Jesse Dringoli, Bentley Technical Support Group |
When trying to open the software after installation, or when opening the License Tool, one of the following errors occur:
"This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
"The application has failed to start because its side-by-side configuration is incorrect."
This can occur in some cases if one or more Windows components that the software relies on becomes corrupt. On installation, the software will check if the correct version of Microsoft .NET Framework and C++ runtime redistributables are installed. If these components are installed on your computer but either corrupt or missing files, the software will not attempt to reinstall, but may not function properly (causing the error
in question).
To resolve this issue, download the appropriate version of .NET Framework and C++ 2005 redistributable from Microsoft.com and install them. This should force these components to reinstall. The version of
.NET framework required depends on the version of your OpenFlows/Bentley product, but the latest versions require .NET version 4.5.1.
Microsoft download links for C++ runtime redistributables:
vc8redist_x86.exe (2005): https://www.microsoft.com/en-us/download/details.aspx?id=5638
vc8redist_x64.exe (2005): https://www.microsoft.com/en-us/download/details.aspx?id=21254
vc9redist_x86.exe (2008): https://www.microsoft.com/en-us/download/details.aspx?id=29
vc9redist_x64.exe (2008): https://www.microsoft.com/en-us/download/details.aspx?id=15336
vc10redist_x86.exe (2010): https://www.microsoft.com/en-us/download/details.aspx?id=5555
vc10redist_x64.exe (2010): https://www.microsoft.com/en-us/download/details.aspx?id=14632
vc11redist_x86.exe (2012): https://www.microsoft.com/en-us/download/details.aspx?id=30679
vc11redist_x64.exe (2012): https://www.microsoft.com/en-us/download/details.aspx?id=30679
vc12redist_x86.exe (2013): https://www.microsoft.com/en-us/download/details.aspx?id=40784
vc12redist_x64.exe (2013): https://www.microsoft.com/en-us/download/details.aspx?id=40784
vc14redist_x86.exe (2015): https://www.microsoft.com/en-us/download/details.aspx?id=52685
vc14redist_x64.exe (2015): https://www.microsoft.com/en-us/download/details.aspx?id=52685
Microsoft .NET Framework offline installers:
Microsoft .NET Framework 4.6.1 (Offline Installer)
