| Product(s): | SewerGEMS, StormCAD, Civilstorm, SewerCAD | ||
| Version(s): | 10.XX.XX.XX, 08.11.XX.XX | ||
| Area: | Modeling |
When executing Network Navigator with the trace downstream query or when Validating the model, the following error or user notification appears:
Error executing query.
"Pump discharge link is inactive, not selected or does not exist."
Please run validation to find the elements causing the failure
This message means that there is no conduit assigned to the pump downstream link property and it can occur in a few situations.
