| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, StormCAD, CivilStorm |
| Version(s): | 08.11.XX.XX and later |
| Area: | Modeling |
How do I save a model in one of the OpenFlows products integrated with AutoCAD (WaterCAD for AutoCAD, WaterGEMS for AutoCAD, SewerGEMS for AutoCAD, etc...)
Normally, when you save a file in WaterCAD, SewerGEMS, WaterGEMS, SewerCAD, CivilStorm, etc... you go on the File menu for the software and save the file with the programs correct extension (.wtg, .swg, .stsw, .swc, etc...). In the case of our products in the AutoCAD environment you will save the .DWG using the AutoCAD menu options. The .DWG file is then linked to the model files for the program you are using.
If you are working in SewerGEMS for AutoCAD, and do a "Save As", it will save a new copy of the DWG and will also create new copies of the model files.
