| Product(s): | WaterCAD, WaterGEMS, HAMMER, SewerGEMS, SewerCAD, StormCAD, CivilStorm |
| Version(s): | 08.11.XX.XX and 10.XX.XX.XX |
| Area: | Installation |
The following error is appearing:
"System.TypeInitializationException"
When closing the program:
System.TypeInitializationException: The type initializer for 'Haestad.Domain.LibraryObjects.EngineeringLibraryService' threw an exception. ---> System.Runtime.InteropServices.SEHException: External component has thrown an exception.
at DAO.Workspace.CreateDatabase(Workspace* , _com_ptr_t<_com_IIID>* , _bstr_t* Name, _bstr_t* Connect, _variant_t* Option)
at CDaoDatabase.CreateDatabase(CDaoDatabase* , _bstr_t* filename, SByte*locale)
at Haestad.Domain.DaoInterop.DaoDatabase.CreateDatabase(String fileName,CultureInfo locale)
at Haestad.Domain.LibraryObjects.JetAppSettings.OpenRegistryDatabase(StringfileName)
at Haestad.Domain.LibraryObjects.EngineeringLibraryService.OpenImpl()
When opening the program:
Haestad.Domain.DaoInterop.DAOException (0x80040154): COMerror not documented
at Haestad.Domain.DaoInterop.InteropLibrary.ThrowCOMException(_com_error* e)
at Haestad.Domain.DaoInterop.DaoDatabase.CreateDatabase(String fileName, CultureInfo locale)
at Haestad.Domain.LibraryObjects.JetAppSettings.OpenRegistryDatabase(String fileName)
at Haestad.Domain.LibraryObjects.JetAppSettings..ctor(String filename)
at Haestad.Domain.LibraryObjects.EngineeringLibraryService..cctor()
When opening a file:
at Haestad.Domain.LibraryObjects.EngineeringLibraryService.set_ProjectWiseManager(ProjectWiseManager value)
at Haestad.Framework.Application.ProjectManagerBase.get_ProjectWiseManager()
at Haestad.Framework.Application.ProjectManagerBase.get_IsProjectWiseAvailable()
at Haestad.Framework.Application.HaestadParentFormModel.get_IsProjectWiseAvailable()
at Haestad.Drawing.Control.Application.GraphicalParentFormUIModelBase.Initialize()
at Haestad.Drawing.Control.Forms.GraphicalDrawingParentForm.DoLazyInitialization(Boolean lazyInitialize)
at Haestad.Drawing.Control.Forms.GraphicalDrawingParentForm.FileNew()
at Haestad.Montana.Forms.MontanaXMParentForm.FileNew()
at Haestad.Framework.Windows.Forms.Forms.WelcomeForm.buttonCreateNewProject_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The error could be occurring because of unregistered DAO. See this article for steps to register the DAO360.dll file.
You can find the steps to perform clean uninstall and re-install the program here.
You can find the steps to upgrade to the latest version here.
You can find the steps to delete engineering libraries here.
How do I download the Water and Storm-Sewer hydraulics and hydrology products?
How do I perform a clean uninstall and reinstall of the Hydraulic and Hydrology products?
