| Product(s): | WaterGEMS, WaterCAD | ||
| Area: | Output and reporting |
How can I find the volume of water coming from an element that I set as the trace element in my pipes or my junctions?
Problem ID#: 75149
This can be done using the Water Quality Batch Run tool. Set up a trace for one or more source, then use the Graph button at the top of the tool to select and graph results for that element, including cumulative volume.
Using Water Quality Batch run for multi-point trace and multiple constituents
