| Product(s): | WaterGEMS, WaterCAD, HAMMER |
| Version(s): | 10.00.xx.xx, 08.11.xx.xx |
| Area: | Modeling |
Does changing the friction method in the calculation options change the local minor losses applied to the pipes in the model?
Problem ID#: 62665
No, the local minor losses are not affected by changing the friction method.
How do you find or change the friction method used in WaterGEMS and WaterCAD?
