| Product(s): | HAMMER |
| Version(s): | 10.03.02.75 |
| Area: | Installation |
CONNECT Edition Update 3 version 10.03.02.75 of HAMMER introduces improvements and features to help you be more successful.
Stability enhancements and fixes to reported issues
New properties fields are included which enables HAMMER to adjust a PSV and FCV opening dynamically during a transient analysis. While a similar feature was available for PRVs, you can now follow a similar workflow to include opening and closing rate coefficients for PSVs and FCVs.
More information can be found in the following link: Using Modulating PRV, PSV or FCV during a transient simulation
There are three predefined turbine curves available. Each curve can be used by turbines with specific speed in a certain range. Starting with this release, the range information for the turbine curve for a turbine specific speed selection is available in the Properties grid and FlexTable.
For more information on turbines, see the following link: Modeling Reference - Turbines.
Compatible Operating Systems
Supported Platforms:
Models saved in older versions of HAMMER can be opened in other 10.03.XX.XX releases,
See also: Model backward / forward compatibility
As with all new versions, this release of HAMMER includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
