| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
On the top right of the page, select for which elements to display reports:
| Sensor Report (this page) | |
| Zone Report | |
| Large Customers Report |
Sensor report gives the operator quick access to all monthly input volumes in the system for each sensor and daily minimum values achieved in each month for each sensor
Integration along time of the flow time series data for the specific month to produce the cumulative volume. WaterSight uses advanced analytics and machine learning techniques to remove outliers and bad data. The volume is computed taking into consideration the following:
The "Daily Minimum" tab reports minimum monthly values for flow, Pressure and Level depending on the selected measurement and for the time period selected, based on the 15 minutes time step series.
The measurement type of sensors to report on. Available options are Flow, Pressure and Level.
This control in enabled for the "Daily Minimum" tab only as the volume only flow specific.
The period the report is created for. The user can choose between last month, last 3 months, last 12 months, last 24 months, year to date or prior (calendar) year.
Exports the report to a csv file for further processing data e.g. with a spreadsheet software.
