| Product(s): | WaterGEMS, HAMMER, SewerGEMS | ||
| Version(s): | CONNECT Edition, V8i | ||
| Environment: | ArcGIS Pro, ArcMap |
How do I automatically get my layers in WaterGEMS, SewerGEMS, and HAMMER for ArcMap and WaterGEMS and SewerGEMS for ArcGIS Pro to populate the symbology used in the standalone version?
Why do all of my node element icons appear as circles when using the ArcGIS integrated platform?
Starting with WaterGEMS 2024 and SewerGEMS 2024 (version 24.00.00.XX and higher), the icon symbology in the drawing and in the Layer Contends will automatically display the icon symbology for the OpenFlows elements.
If you are using an older version of these products, or if you are using ArcMap, the default icon is used. This is expected because the circle is the default icon for point layers in ArcGIS Pro or ArcMap platform. To display different symbol for different hydraulic element types, you can assign the icon symbology to the respective layer in the Table of Contents. A standard library of icons (similar to the ones seen in the Standalone version) is available for most versions.
The method to change the symbol is different between ArcGIS Pro and ArcMap.
ArcGIS Pro methodology
For WaterGEMS and SewerGEMS versions 23.00.00.XX and earlier using ArcGIS Pro, go to the Insert tab, then go to Styles > Import. Select the .style file from the installation folder. The default locations are as mentioned in installation folder link.
This will create the .stylx file needed for the next step.
Next, go to Insert > Style > Add > Add Style. Browse to the .stylx file.
ArcMap methodology
1) First, see if there is a style file already stored in the WaterGEMS installation folder . This file will be called either "WaterGEMS_CONNECTEdition.style" (for WaterGEMS CONNECT Edition) or "wtrgV8i.style" (for WaterGEMS V8i). If you do not have a style file, download this WaterGEMS for ArcMap Style file and save the file in installation folder on a 64 bit computer. You can save it to any other location but the WaterGEMS installation file is the recommended location so that it is not misplaced.
2) Open WaterGEMS for ArcMap. From that ArcMap toolbar click Customize > Style Manager...
3) In the Style Manager window click the 'Styles...' button on the upper right hand side. This will open the Style References window.
4) In the Style References window click the 'Add Style to List...' button and browse to the location that you saved the style file in step 2 and then click the Open button.
5) After that click the "Set as Default List" button on the Style References window to add this style to the default list that is populated when opening ArcMap. Next hit the OK button to close the Style References window.
6) Finally, click the "Close" button to close the Style Manager window.
Now when you go to add in a new or existing WaterGEMS projects all the WaterGEMS symbology will automatically come in when the layers are added to the table of contents.
** If you wanted to only bring in a few icon for the WaterGEMS layers (eg. just the pipes, junctions, pumps, and tanks) you could locate the newly added style in the Style manager window and click the "+" plus sign next to it. This expands the items that make up the style. Next click on the 'Marker Symbols' folder which opens the symbol names and their icons on the right side of the window. The last step is to simple add an underscore 1 "_1" to the end of the name for the element. Then click the close button. The next time you add an existing model or a new model that layers (elements) symbol we result to the default symbol. See the screen shot below. **
ArcMap methodology without automatically populating Layer Symbology
The steps below describe how to simply add the WaterGEMS symbol style to ArcMap without automatically having the WaterGEMS icons populate the layer symbology can be found here.
On the main ArcMap toolbar go to Customize > Style Manager...
Click the "Style" button on the far right side of this window.
Click the "Add Style to List..." button in lower left corner of the window
Browse out to installation folder (on a 64 bit computer and locate the file called "wtrgV8i.style". Click on it to select it and hit the "Open" button.
Now click the "OK" button to close the "Style References" window and then click the "Close" button to close the "Style Manager" window.
Go to each symbol in the Table of Contents and when you go to change the symbol by double clicking on it the WaterGEMS symbols there will be an option to choose from the list.
WaterGEMS for ArcMap and WaterGEMS for ArcGIS Pro FAQ's
SewerGEMS for ArcMap and SewerGEMS for ArcGIS Pro FAQs
