| Product(s): | WaterGEMS, SewerGEMS, HAMMER | ||
| Environment: | ArcMap | ||
| Area: | Modeling | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
After working on a project in ArcMap integrated mode and saving an .mxd, why does the model not appear when reopening the .mxd?
After reopening the map, you must load the WaterGEMS/SewerGEMS/HAMMER project from the Hydraulic Model Manager. For example for WaterGEMS this would be under WaterGEMS > View > Hydraulic Model Manager.
To open an existing model, click the Open Hydraulic Model button. You can also close a hydraulic model or add a new model through the Hydraulic Model Manager.
Note: This does not apply to ArcGIS Pro
