| Product(s): | WaterGEMS, SewerGEMS |
| Area: | Modeling |
| Environment: | ArcGIS Pro |
How to change the size of the flow arrows when working in the ArcGIS Pro platform.
First, make sure that you have flow arrows enabled. In the Contents menu, right-click and select Symbology. Click the symbol to open the sizing properties.
Click the "Enable scale-based sizing" box and adjust the scale.
When you click Apply, the flow arrow size will change in the drawing.
