| Product(s): | SewerGEMS |
| Area: | Modeling |
Create/Open/Save Models
Creating a new model in WaterGEMS or SewerGEMS for ArcMap or WaterGEMS or SewerGEMS for ArcGIS Pro
Opening an existing WaterGEMS or SewerGEMS model when integrated with ArcMap or ArcGIS Pro
How do I save my model files when working in the ArcMap or ArcGIS Pro platform?
Installation, Compatibility, Integration
Which versions of WaterGEMS and SewerGEMS support which versions of ArcGIS Pro or ArcMap?
Data Conversion (i.e., import/export)
Preparing GIS data for use in the hydraulics and hydrology products
How can I convert my GIS data to a water or storm-sewer model inside ArcMap or ArcGIS Pro?
General
Geodatabase (.mdb), Geotable, and ArcMap Document File (.mxd or .aprx)
Licensing
Why is my license listed as "Not Available" under the extensions (Customize > Extensions) in ArcMap?
Element Symbology
How do I color code my elements in WaterGEMS/SewerGEMS for ArcMap or ArcGIS Pro?
Apply OpenFlows icon symbology to elements in the ArcMap or ArcGIS Pro platform
How can I enable the flow arrows when working in the ArcGIS Pro or ArcMap platform?
OpenFlows Product TechNotes And FAQs
