This is a list of articles containing general FAQs for Bentley SewerCAD.
To search within this page, press [Ctrl]+F.
Import and Export
How to export a selection set to shapefiles
How to export model elements to shapefiles
Submodel Importing and Exporting
FlexTables
Customizing FlexTables for viewing and reporting data -- Moving, adding, and removing columns
New Flextable features in 08.11.06.58+ (Water products) and 08.11.05.113+ (Storm/Sewer products)
General
Can I restore a backup file of my model project?
Property grid, Element FlexTable, or other dialog will not open
Why do I keep getting prompted to compact the database when I open my model? What does this mean?
Input
Are minor losses from pipe bends automatically considered?
Building A Model Using ModelBuilder
Changing symbol size, text height, or line width for elements in a model
Element label editing and automatic numbering
Importing a CAD (DXF) Drawing Using Modelbuilder
Inserting or laying out pipe bends
Modifying and adding entries to Engineering Libraries
Scenario and Alternative Management
Setting Boolean (True/False) Fields using Model Builder
Should I use the inside diameter or outside diameter for the "diameter" field for my pipes?
Updating A Model Using Model Builder
Updating Source File Using Model Builder
What is the asterisk column in the Alternative Editor Dialog Box used for?
Output and Reporting
Changing drawing style for better viewing of element symbols and annotations
Changing the default property values when creating model
How can I find the total volume of water through a certain element?
How can I remove or display pipe flow arrows?
How do you add color coding or annotation to an element?
Using Fit To Page Printing In The Standalone Platform
Why aren't known flows adding up?
Why do I sometimes see a negative flow through a pipe?
Troubleshooting
Why does flow or velocity sometimes decrease when moving downstream?
Why is it that no matter how large the inlet on grade is the gutter spread always remains the same?
Why is the HGL reset to rim elevation for flooded structures?
Zero overflow at manhole despite HGL above rim.
CivilStorm Product Information
