| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack, HAMMER | ||
| Area: | Output and Reporting | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group |
View Calculation Summary for multiple scenarios after a Batch Run.
To open the Calculation Summary Dialog in CONNECT Edition, go to Home > Summary or Analysis > Summary. In V8i, go to Analysis > Calculation Summary
To view the summary for a different scenario after computing a Batch Run:
1. Close the Scenario Calculation Summary dialog
2. Change the current scenario
3. Open the Calculation Summary again.
Note: Options for changing the current scenario are discussed in the wiki "Scenario and Alternative Management".
To create a report with Report Builder in PondPack:
1. Compute the scenarios to be compiled with Report Builder using Batch run
Note: The Batch Run process is explained in the wiki "Scenario and Alternative Management" and in the help article "Running Multiple Scenarios at once (Batch Runs)".
2. Open Report Builder
Option 1 - From the Scenario Calculation Summary dialog
Click the Report button and select Report Builder
Option 2 - From the Report menu
Option 3 - Press [Ctrl+R]
3. In the Report Builder Scenario Selection dialog:
a. Check the calculated scenarios to include in the report
b. Click OK
4. In the Report Builder dialog:
a. Select the sections to include in the report
b. Enter a Report Title
c. Click the down arrow next to the Generate Preview icon
d. (Optional) Select the Options button and edit the project properties and page setup.
e. Select Full Report
Help: Running Multiple Scenarios at Once (Batch Runs)
