| Product(s): | OpenFlows FLOOD |
| Version(s): | 10.03.00.01 |
| Area: | Modeling |
This article briefly explains how to visualize Lagrangian model results (when MOHID Water's numerical engine for coastal applications) in OpenFlows FLOOD 10.03.00.01.
In version 10.03.00.01 of OpenFlows FLOOD when loading an HDF5 output file containing Lagrangian particles cloud model results the software becomes unresponsive due to an incompatibilty between the user interface and the format of the HDF5 file written by MOHID Water.
The solution to this problem is to use a corrected version of MOHID Water executable that correctly writes the results in a format that OpenFlows FLOOD can read.
You may download the corrected executable file here:
communities.bentley.com/.../8877.MOHIDWater_5F00_OpenFlowsFLOOD_5F00_10.03.00.01.zip
Follow the steps below to correctly use this executable in OpenFlows FLOOD:
