| Product(s): | SewerGEMS, CivilStorm, StormCAD, SewerCAD |
| Version(s): | 10.03.00.77 / 10.03.00.78 |
| Area: | Installation |
The new CONNECT Edition Update 3 release of SewerGEMS, CivilStorm, SewerCAD, and StormCAD (build 10.03.00.xx) introduces improvements to help you be more successful.
Note: this was initially release as version 10.03.00.75 but later re-released as 10.03.00.77 (and 10.03.00.78 for SewerGEMS) to incorporate address a few issues (missing implicit calculation options, AutoCAD 2020 integration issue, Z coordinate not showing on mouse-over a terrain model and chart options showing in Chinese)
Stability enhancements and fixes to reported issues
Supported Operating Systems
Compatible Platforms
Supported Platforms:
Support for EPA-SWMM 5.1.013 has been included in the Explicit solver for SewerGEMS and CivilStorm. Also, new options and properties have been added to elements and calculation options in support of the new solver version, such as the "Surcharge Method" (Slot or Extran) calculation option.
The updated Flood Estimation Handbook (FEH 2013) rainfall model is now supported as a storm type within Storm Data dialog. You will be able to get a point-based XML file from the FEH Web Service and import this into the Storm Data dialog.
Support or the Chinese (XinAnJiang) Rainfall-Runoff Method has been included in the latest version of SewerGEMS and CivilStorm. This is not currently included with the GVF solvers in the storm-sewer products. This is only available in the Chinese language version of SewerGEMS and CivilStorm.
Enhancements to the hydraulic calculations and reporting when an OpenRoads Designer user is further empowered with a license of OpenFlows StormCAD, SewerCAD, CivilStorm, or SewerGEMS. For more information on modeling subsurface utilities in OpenRoads Designer, see the following link: Understanding OpenFlows Hydraulics and Hydrology Functionality in Subsurface Utilities / OpenRoads.
Models saved in earlier versions of SewerGEMS, StormCAD, SewerCAD and CivilStorm can be opened in this version.
See: Model backward / forward compatibility
As with all new versions, this release includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
Downloading OpenFlows / Hydraulics and Hydrology Software
Cumulative patch set information
Set up notifications for new versions and patch set releases
