OpenFlows Product Licensing FAQs and Troubleshooting
Product(s): StormCAD, SewerCAD, WaterCAD, CivilStorm, WaterGEMS, Hammer, PondPack, CulvertMaster, FlowMaster
Version(s): V8 XM, V8i, CONNECT Edition
Area: Licensing
Below you will find a list of articles related to activating (licensing) Bentley OpenFlows products.
How to: Subscription Entitlement Service Licensing (version 10.02.XX.XX and greater)
The following articles contain detailed information on how Bentley's OpenFlows product licensing and activation works and how to configure it.
Licensing OpenFlows products - Subscription Entitlement Service
Setting the License Feature Level in the Feature Level Selector (Subscription Entitlement Service / CONNECT Licensing)
Benefits of the Subscription Entitlement Service (CONNECT Licensing) for OpenFlows Users
Controlling license access to prevent unintended usage
Monitoring License Usage - Subscription Entitlement Service (CONNECT Licensing)
How do OpenFlows product licenses work with element limits?
Find registration / license information and version / build number for Hydraulics and Hydrology products
Perform a clean uninstall and reinstall of the Hydraulic and Hydrology products
Setting the Default Feature Configuration as an Administrator, for other Windows Accounts
Locate the CAiHE Licensing and Activation Key
Troubleshooting
The following articles can assist in troubleshooting licensing related errors or warnings.
What do the different license statuses mean?
User Notification: "The number of active <element type> in this model exceeds the number of <element type> allowed for your license"
Usage Logging / Reporting
License usage logging for multiple instances of the same product on a machine
License usage with AutoCAD integration
At what point does license usage start when integrated with MicroStation?
Do inactive elements count against the license count?
How does a checked out license work for SELECT or ELS customers with product usage logging?
