| Product(s): | PondPack, StormCAD, CulvertMaster, FlowMaster |
| Version(s): | All |
Are Bentley's OpenFlows stormwater products (listed above) FEMA approved? If yes, which versions are FEMA approved?
As of September 2026, StormCAD and PondPack (8.0 and higher) are FEMA approved. CivilStorm models using the EPA SWMM solver are also accepted by FEMA. Refer to FEMA's website.
The use of FlowMaster is approved by FEMA for normal depth calculations to establish base flood elevations for Letter of Map Amendment and Letter of Map Revision based on fill requests along streams, creeks, and rivers designated as approximate Zone A on NFIP maps. (Note: FlowMaster is not on FEMA’s Nationally Accepted Hydraulic Models list.)
Note:
Validation or Certification documents for Hydraulics and Hydrology products
