| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, HAMMER, StormCAD, CivilStorm, SewerCAD |
| Area: | Output and Reporting |
Is it possible to add color coding based on multiple conditions / attributes together?
For example, combinations of "Flow reversal ever occurred" and maximum velocity, or combinations of velocity and pipe diameter.
When applying color coding to model results, it is applied in a certain order, and currently only one attribute can be color coded on in a given color coding definition. However if there is a need to visualize elements satisfying multiple conditions at a time (for example combinations of if the flow is reversed in pipes and maximum velocity) you can use query-based selection sets to satisfy these conditions by applying multiple color codings in a specific order to get the required result.
Below are sample steps to set up color coding for the condition of: flow reversal ever occurred + maximum velocity < 0.5 m/s, in the same way other criteria’s can be fulfilled using creativity.
1) Using the Queries window, Define a Query on Pipe - Flow Reversed Ever? = True (IdahoFlowDirectionResults_FlowDirectionReversedEver = True)
2) Define a Query Based Selection Set based on the query you just defined.
3) Define 2 color coding’s (see below for details), one for flow reversed pipes and one for pipes where velocity is < 0.5 m/s based on selection set created earlier.
Note: Color codings get applied in order (from bottom to top), so be sure they are in the proper order. Use the shift buttons to rearrange things. In the example shown, they are grouped in a folder so they can be turned off together.
This will apply the color coding for these two conditions together, based on the order of color coding created or applied.
Note : After making any changes to the model or after re-computing the model, if the color coding is not applied correctly, click on refresh button in element symbology, as it happens with query based selection sets.
Query based selection sets not updating in various tools such as color coding and annotations
