| Product(s): | WaterGEMS, WaterCAD |
| Area: | Output and Reporting |
How do I remove the "N/A" entries in the Fire Flow Node Table for nodes not included in the Fire Flow Nodes selection set in the Fire Flow alternative?
Starting with WaterGEMS and WaterCAD CONNECT Edition Update 3 (version 10.03.04.05), the Fire Flow Node Table will be automatically filtered to only display results for elements selected in the Fire Flow Nodes pulldown menu in the Fire Flow alternative.
If you are using an older version or are unable to upgrade to a later version that includes this feature, you may see nodes listed in the Fire Flow Node Table that have no results and will display N/A. In such a case, you can filter the Fire Flow Node Table using one of the following methods:
Option 1
Option 2:
Option 3:
Understanding Automated Fire Flow Results
Why does the Pressure (Calculated Residual) field display N/A for a steady state or EPS run?
Results show as "N/A" when clicking a node in the Fire Flow Results Browser
