| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, CivilStorm, StormCAD, HAMMER, PondPack | ||
| Version(s): | 08.11.XX.XX and later | ||
| Area: | Calculations | ||
| Original Author: | Scott Kampa, Bentley Technical Support Group |
When opening or computing a model, the following message is generated:
"Access to path ______ is denied"
If the error occurs when attempting to compute the model and displays the path to the model file you are trying to open, the problem may be related to the user permissions for that particular folder. Check your Windows user permissions and permissions to that particular folder. Contact your Administrator if needed.
If the error refers to a temporary folder path, this can occur if there is an issue with a file in the temp folder. Note that the path to the temp folder may be different on different machines. Close the program and browse to the temp folder. Delete the items in the folder. Reopen the program and compute the model. The error message should no longer occur.
Browse to where you files are located and delete all the output files except those necessary to run the model. The necessary files for the OpenFlows hydraulic programs can be found in this wiki. As an example, for WaterGEMS, you can move the .wtg and .wtg.sqlite files to a new folder. For SewerGEMS, the files would be the .stsw and .stsw.sqlite files. For PondPack, the files would be the .ppc and .ppc.mdb files.
Browse to C:\Users\<Username>\AppData\Local\Bentley\<product name>\<version>\ and make sure that the files here are not set as Read-Only.
For example, if the file path was "D:\<folder1>\<folder2>\folder<3>\folder<4>\" try saving it to "D:\<folder1>\<folder2>\"
Take the files associated with the program and move them to a location on the C: drive
