| Product(s): | WaterGEMS, WaterCAD, HAMMER, SewerGEMS, StormCAD, SewerCAD, CivilStorm, PondPack |
| Area: | Installation |
Silent Install Syntax
Deployment Images
Older Silent Installs
Preventing Integration
Command line Arguments
Patches
CONNECTION Client Silent Install
Troubleshooting
Silent Uninstallation
Version-specific details
Silent Licensing Selection
As a systems administrator, it is sometimes necessary to install one or more of Bentley's OpenFlows Water, Storm and Sewer products silently, so that no prompts appear on the client side. A script may be needed to push this out from a server using SCCM for example.
OpenFlows product versions released in October 2025 onward (starting with FlowMaster 2025 and OpenFlows Water/Storm/Sewer 2026) use the new Bentley standard installers, which can create a deployment image, to facilitate both the silent aspect, as well as customized installation options such as the path, which specific products to install, whether or not to integrate with other applications, and other options.
The silent install syntax varies depending on the version. Use the table below to determine which method to use with the version you are deploying. Further details on each method are displayed in the sections that follow, along with details on how to specify a custom installation folder path, prevent lessons and samples from being installed, or disable integration with AutoCAD, MicroStation or ArcMap.
| Product | Version | Installer Technology | Silent install syntax |
| OpenFlows Water, Storm and Sewer | 2026 | Bentley | /layout |
| OpenFlows Water, Storm and Sewer | 2023 and 2024 | Wix | /q |
| WaterCAD/WaterGEMS/HAMMER | 10.00.00.55 through 10.04.XX.XX | Wix | /q |
| WaterCAD/WaterGEMS/HAMMER | 10.00.00.50 | 7Zip/Wix | /gm2 /ai |
| StormCAD | 10.00.00.45 through 10.03.XX.XX | Wix | /q |
| StormCAD | 10.00.00.40 | 7Zip/Wix | /gm2 /ai |
| SewerCAD | 10.00.00.45 through 10.03.XX.XX | Wix | /q |
| SewerCAD | 10.00.00.40 | 7Zip/Wix | /gm2 /ai |
| SewerGEMS | 10.00.00.45 through 10.03.XX.XX | Wix | /q |
| SewerGEMS | 10.00.00.40 | 7Zip/Wix | /gm2 /ai |
| CivilStorm | 10.00.00.45 through 10.03.XX.XX | Wix | /q |
| CivilStorm | 10.00.00.40 | 7Zip/Wix | /gm2 /ai |
| PondPack | 10.00.00.02 and 10.02.00.01 | Wix | /q |
| FlowMaster | 25.00.00.982 | Bentley | /layout |
| FlowMaster | 10.00.00.02 through 10.03.00.03 | Wix | /q |
| CulvertMaster | 10.03.00.02 | Wix | /q |
Deployment images are created using the /layout switch when running the executable, for OpenFlows Water/Storm/Sewer version 2026 and greater, and FlowMaster version 2025 and greater. This facilitates both the silent aspect ("No UI mode"), as well as customized installation options such as the path, which specific products to install, whether or not to integrate with other applications, and other options. Additionally, deployment images will download all the needed components, creating an offline installer which does not require internet (normally starting with version 2026, the executable files from the Software Downloads site are just small online installers which download the information during installation)
IMPORTANT: there is a known issue in version 26.00.00.508 and 26.00.00.513 causing the deployment image to not include the selected applications. This has been fixed in version 26.00.00.514.
As an administrator, you can run the installation file with the /layout syntax (from the Windows Run window for example) and step through the process - it will look like you are installing but you will actually be configuring the settings that will be used when the deployment image is later run on the end user computers. Choose the desired options including the installation path and which products will be installed.
For example you may only want to deploy WaterGEMS (silently) without integrating with AutoCAD. So, you would use the /layout syntax against the OpenFlows Water installer, choosing "No UI", choosing only WaterGEMS and unchecking the AutoCAD integration option. This creates a .lyt file - when present next to your installation executable, it will automatically find and use it to apply the desired deployment settings.
Note: after you configure the deployment image, it will download all the necessary files, creating an offline installer that does not require internet.
For details, refer to the following articles for other Bentley products that also use this standard Bentley installer and deployment image creation capability:
For earlier versions, a deployment package option is not available. Also, the MSI installation file for the older OpenFlows products is contained within the installation executable file and is not readily available. If you do not wish to use the silent install option detailed below with the original installation executable file, you can extract the contents of it (including the MSI and prerequisites) and re-package them for deployment using a Wix tool called dark.exe per this article: Extracting Setup contents and prerequisites
See further below for information on deployment images for the CONNECTION Client prerequisite.
Note: using our current OpenFlows Water, Sewer, and Storm installers, it is not possible to keep previously-installed products and just add another one while reinstalling. This is a limitation of the bundle implementation behavior in the software we use for building our installations. To add or remove products (which are just installation features) you must uninstall the entire product, and then reinstall with the new set of products.
The following is an example syntax to silently deploy WaterGEMS 2024, without any options added (see further below for additional options)
Setup_WaterGEMS_x64_24.00.00.26.exe /q
Starting in July 2024 (version 24.00.01.XX and higher), consolidated installation files are used for the new consolidated products, OpenFlows Water, OpenFlows Sewer and OpenFlows Storm. For example the installation file for OpenFlows Water includes WaterCAD, WaterGEMS and HAMMER (no separate installers anymore). Details on the consolidation can be found here.
For the 2026 version (and higher), create a deployment image per the information above (/layout syntax), and choose which application(s) you would like to be installed. This will create a new deployment image which when run, will install only those application(s).
For the 2024 version, the /q syntax can be used per the table above but if you do not include any other command line arguments, only the first entry in the respective tier will be installed (for example for OpenFlows Water, only WaterCAD will be installed).
If you want to install all products within the 2024 version's package, you will need to include the command line argument "ADDLOCAL=ALL". For example to install WaterCAD, WaterGEMS and HAMMER from OpenFlows Water:
Water_24.00.01.05_en.exe /q ADDLOCAL=ALL
If you only want to silently install WaterGEMS for example, use this:
Water_24.00.01.05_en.exe /q ADDLOCAL=ALL REMOVE=WaterCAD,HAMMER
See "Available Command Line Arguments" further below for a complete set of options that can be omitted/skipped during silent installation.
NOTE: regardless of which applications you choose to install (via the syntax above), all older versions will always be uninstalled first. For example for OpenFlows Water, if you use "REMOVE=WaterCAD,HAMMER" to only install WaterGEMS, it will still first uninstall any older WaterCAD of HAMMER versions you happen to already have installed. This behavior is by-design, in order to avoid compatibility issue. If you absolutely must have the old versions of WaterCAD and HAMMER installed, our suggestion is to copy and paste their installation folder to another location, then run the installation routine. This will install the latest WaterGEMS and uninstall WaterCAD and HAMMER, but leave the install folders behind since you copied them to a new location. You can then move the folder back, and the Standalone version will continue to work (via the shortcuts, or by running the watercad.exe or hmr.exe file located within their respective installation folders. Integrated platforms (MicroStation, AutoCAD and ArcGIS) may not function correctly.
With the versions whose installation packages are based on IEpress/Wix (see table above), a silent installation of a newer version should automatically uninstall the older version first. There should be no prompt appearing on the user side.
For Installshield generation versions and below, you may need to uninstall the existing older version first (see further below on silent uninstallation).
In some situations you may want to prevent the silent installation of the software from integrating with other platforms and creating shortcuts such as "WaterGEMS 2024 for AutoCAD...".
For version 2026 and greater, create a deployment image per the information above (/layout syntax), and uncheck the AutoCAD, MicroStation or ArcGIS options within each product if you do not want those shortcuts to be created. This will create a new deployment image which when run, will not integrate with those platforms.
For versions released between 2020 and 2025 (10.03.02.XX through 24.XX.XX.XX), you can use the following silent mode command line argument syntax with the normal installation file, to specify which integration options to remove during installation (plus the ability to specify the installation folder path and whether or not lessons and samples are installed):
<Installationfile.exe> /q INSTALLDIR="<folder path>" ADDLOCAL=ALL REMOVE=<comma-separated list of features to remove; see "Command Line arguments" section below>
Note: for versions released before August, 2020 (ex: 10.03.01.XX and earlier for most OpenFlows products), this is not possible with the installation file alone. You must extract the setup.msi file and use the below syntax:
msiexec /i setup.msi ADDLOCAL=ALL REMOVE="MicroStation,ArcGIS,AutoCAD,AutoCAD_x64"
See below list of available features that can be used with the REMOVE= command line argument to remove (skip) them during silent installation. This is applicable to the older versions that use the /q syntax. Note:
Here is an example silent mode command line for WaterGEMS 2024 (note the syntax difference starting in version 2024) that changes the install folder location and removes AutoCAD integration and does not install shortcuts on the desktop and Sample and Lesson files:
Setup_WaterGEMS_x64_24.00.00.26.exe /q INSTALLDIR="D:\Bentley Products\WaterGEMS" ADDLOCAL=ALL REMOVE=WaterGEMSAutoCAD,WaterGEMSDesktopShortcuts,WaterGEMSSamplesAndLessons
Here is a list of all features supported per product, which can be skipped using the REMOVE= argument:
OpenFlows Water (packaging of WaterCAD, WaterGEMS and HAMMER)
OpenFlows Sewer (packaging of SewerCAD and SewerGEMS)
OpenFlows Storm (packaging of StormCAD and CivilStorm)
WaterGEMS:
WaterCAD:
HAMMER:
SewerGEMS:
SewerCAD:
StormCAD:
CivilStorm:
CulvertMaster, FlowMaster, PondPack: SamplesAndLessons, DesktopShortcuts
Note:
Cumulative patch sets with file extension .msp have the ability to be installed silently as well, with the following syntax (using a WaterGEMS patch as an example):
Msiexec /update WaterGEMS_10.03.01.08_en.Patch06.msp /q
The Bentley CONNECTION Client is installed as a prerequisite in order to license the product (SES licensing-enabled versions). To install the CONNECTION Client itself, silently, see the below articles. In particular, note the syntax required to prevent the CONNECTION Client from opening after installation. Also note that if you are on a 64-bit Operating System, installing the 64-bit version of the OpenFlows product, you will want to silently deploy the 64-bit version of the CONNECTION Client.
CONNECTION Client Silent Installation
How to Create a Deployment Image
The CONNECTION Client has a set of prerequisites, similar to the program installation file. If these prerequisites are not already on the computer, they will be installed by the CONNNECTION Client installer. As mentioned in the "Note on .NET Framework" section above, you may want to install these prerequisites first before installing CONNECTION Client.
If you're having trouble performing a silent installation, try extracting all the contents and silently deploying them separately. See "Older IEpress/Wix Installers" section below for more information.
Starting with version 24.00.01.XX, combined installers are used, so for example the "OpenFlows Water" installer deploys WaterCAD, WaterGEMS and/or HAMMER. These versions do not have the ability to silently uninstall specific applications - only the entire OpenFlows Water/Storm/Sewer. So for example if you have OpenFlows Sewer 2024 installed with both SewerGEMS and SewerCAD, but you want to silently remove only SewerGEMS (leaving only SewerCAD), you would need to silently uninstall OpenFlows Sewer (using the steps below
To perform a silent uninstallation, run msiexec with the following syntax:
msiexec /x {GUID} /qn
The "GUID" is a globally unique identifier that is specific to the combination of product and version. On a 64-bit operating system, the GUID for OpenFlows product versions 2024 and earlier (which use a 32-bit installer) can be found in the registry under:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\
...and OpenFlows products released in 2025 onward (which use 64-bit installers) can be found under:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
For example for WaterGEMS 08.11.04.50, the guid is {BE30126E-C93C-4C98-97EA-3EEBB4F2561F}, so you would run it like this:
msiexec /x {BE30126E-C93C-4C98-97EA-3EEBB4F2561F} /qn
Recent versions of OpenFlows products (as of ~2010-2013) utilize IEpress to extract the installation files and Wix to package the .msi. Versions using this technology can be silently installed by running the install file with the either the /gm2 /ai or the /q:a switch, depending on the version. See the table above for the syntax needed.
A server script would need to execute this on the client computerO, with the install file in a shared/network location. Two exceptions are version 08.11.02.31 of WaterCAD, WaterGEMS and HAMMER, and version 08.11.01.51 of PondPack (see "older IEpress/Wix" section below for these).
When run, the program will attempt to install without any user interaction.
When the IEpress and Wix technology was first used in our installers, we did not support passing of the silent mode switch (/q:a). This applies to version 08.11.02.31 of WaterCAD, WaterGEMS and HAMMER, and version 08.11.01.51 of PondPack.
For these versions, you must first extract the prerequisites and setup msi file and deploy them silently. A server script would need to execute this on the client computer, with the install file in a shared/network location.
1) Extract the contents of the installation executable to a folder, using a tool such as 7zip or WinRAR. You can also use the steps located here for extracting those files.
2) Silently deploy all the prerequisites with standard silent mode arguments. To check the order of installation, look in the Settings.ini file. For example to install the Microsoft .NET Framework prerequisite silently:
dotnetfx35setup.exe /q /norestart
To install Microsoft Visual C++ Redistributable x86:
vc9redist_x86.EXE /q:a /c:"msiexec /i vcredist.msi /qn"
3) Silently deploy the main application, contained within the Setup.msi file. Example:
MsiExec.exe /I Setup.msi /L* %TEMP%\SetupLog.txt /qn
Note: The prerequisite installer also does a test on the prerequisite to see if it is already installed, through a registry check. You can see the registry path in the Settings.ini file. For instance for Microsoft Visual C++ 2008 Redistributable x86 checks if the following registry path is present when the prerequisite is installed so there is no point in installing it:
32-bit OS: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}
64-bit OS: SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}
Versions of the OpenFlows products that use InstallShield technology can be silently installed by running the install file with the /s /v/qn switch. A server script would need to execute this on the client computer, with the install file in a shared/network location.
Old versions of OpenFlows products that utilized Wise installer technology can be silently installed simply by running the install file with the switch /s. A server script would need to execute this on the client computer, with the install file in a shared/network location.
Note: it is highly recommended to upgrade to a newer version, especially for Operating System compatibility reasons.
OpenFlows products are licensed by Feature Level (for example number of pipes, with or without AutoCAD, etc), and so the user must select the feature level that the product will license against when it opens.
Newer, Subscription Entitlement Service licensing:
Starting with CONNECT Edition Update 2 (10.02.XX.XX and greater), the new Subscription Entitlement Service is used for licensing. As of July 2020, there are no command line parameters for setting the feature level with these versions. Improvements to feature level selection have reduced the need for this. See "Can the Feature Level be set remotely or by command line, by an Administrator?" in this article: Setting the License Feature Level in the Feature Level Selector
For older, SELECTserver licensing (NO LONGER SUPPORTED):
To silently configure the feature level, your server script can run command line arguments on the Licensetool.exe and Haestad.LicenseAdministrator.Console.exe both of which are found in the product's installation folder.
To set the server name, use this syntax: LicenseTool.exe /nowin configure -setting:SelectServer -value:SERVER_NAME
To set the activation key, use this syntax: LicenseTool.exe /nowin configure -setting:ActivationKey -value:ACT_KEY
To set a default license feature configuration, (typically done manually in the Municipal License Administrator (MLA), to choose your pipe, inlet or pond limit) use this syntax:
Haestad.LicenseAdministrator.Console.exe /configure <productid> <featurestring>
Where <productid> is the ID corresponding to the Bentley application and <featurestring> is the default feature string you want to set. A typical feature string looks something like this: acad=yes|agis=yes|mstn=yes|pipe=250. Of course, you will need to be licensed for the feature string you set, else the product will not activate (and may run in Disconnected Mode for a limited period of time).
Older, SELECTServer, Option 2:
If the above does not work or you'd like an additional option to use the steps below will explain how to create a copy of the registry entry for your license file. After doing that you can write a script file the enters the information automatically into the registry from the license text file that you'll be creating. Note that you'll have to perform these steps on a computer that already has one of the Bentley Water Products already installed.
1) Browse to "HKEY_LOCAL_MACHINE\SOFTWARE\BENTLEY\LICENSING\1.1" on a 32 bit computer OR "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\BENTLEY\LICENSING\1.1" on a 64 bit computer.
2) With the 1.1 folder highlighted right click and choose > Export.
3) After you save the file you can write a script that reads the information from this file and populates the Select Server and Activation key in the registry at the locations listed above.
Here is the list of Product IDs: Example Configuration:
WaterCAD: 1248 acad=no|mstn=yes|pipe=1000
WaterGEMS: 1249 acad=yes|agis=yes|mstn=yes|pipe=unlimited
HAMMER: 1225 acad=yes|agis=yes|mstn=yes|pipe=500
SewerGEMS: 1244 acad=yes|agis=yes|mstn=yes|pipe=250
CivilStorm: 1207 acad=yes|mstn=yes|link=250
StormCAD: 1246 mstn=yes|inlt=5
SewerCAD: 1243 acad=yes|mstn=yes|pipe=10
PondPack: 1233 acad=yes|mstn=yes|pond=unlimited
To find other configurations open the municipal license administrator and right click on the row with the configuration you want to set and choose "Properties". The configuration can be copied from the window and used in the commands below.
If running this command from the client's computer, use the Run command with the full path to the executable file. The Haestad.LicenseAdministrator.Console.exe file will be located in the product's installation folder. The path depends on where you originally directed the program to install and whether the operating system is 32 ot 64-bit. For example, the Run window for StormCAD running on a 64-bit version of Windows 7 would be like this:
Use this format if executing using the Run command:
C:\Program Files (x86)\Bentley\StormCAD8\Haestad.LicenseAdministrator.Console.exe /configure 1246 "mstn=yes|inlt=25"
Use this format if executing from the DOS command window of a batch file:
timeout /t 3
An example file of this script can be downloaded here.
The following table is for historical documentation of the syntax for versions that are no longer supported.
| Product | Version | Installer Technology | Silent install syntax | .NET required |
08.11.06.113 | 7Zip/Wix | /gm2 /ai | 4.5.1 |
08.11.06.58 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
08.11.05.61 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
08.11.04.58 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.04.57 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.04.50 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.03.19 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.03.17 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.03.16 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.02.31 | IEpress/Wix | /q:a | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.01.32 | IEpress/Wix (older) | N/A | 3.5 SP1 |
| WaterCAD/WaterGEMS/HAMMER | 08.11.00.30 | Installshield | /s /v/qn | 3.5 |
| WaterCAD/WaterGEMS/HAMMER | 08.09.400.34 | Installshield | /s /v/qn | 2.0 |
| WaterCAD/WaterGEMS | 08.09.165.12 | Installshield | /s /v/qn | 2.0 |
| WaterCAD/WaterGEMS | 08.09.165.09 | Installshield | /s /v/qn | 2.0 |
| WaterCAD/WaterGEMS | 08.09.165.00 | Installshield | /s /v/qn | 1.1 |
| WaterCAD/WaterGEMS | 08.09.155.00 | Installshield | /s /v/qn | 1.1 |
| WaterCAD/WaterGEMS | 07.00.061.00 | Installshield | /s /v/qn | 1.1 |
| WaterCAD/WaterGEMS | 07.00.027.00 | Installshield | /s /v/qn | |
| WaterCAD/WaterGEMS | 6.5120n | Wise | /s | |
| HAMMER | 07.01.013.00 | Installshield | /s /v/qn | 1.1 |
| HAMMER | 07.00.060.00 | Wise | /s | |
| StormCAD | 08.11.05.113 | 7Zip/Wix | /gm2 /ai | 4.5.1 |
| StormCAD | 08.11.05.58 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| StormCAD | 08.11.04.54 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| StormCAD | 08.11.03.84 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.03.83 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.03.77 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.02.75 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.02.38 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.02.35 | IEpress/Wix | /q:a | 3.5 SP1 |
| StormCAD | 08.11.00.44 | Installshield | /s /v/qn | 3.5 |
| StormCAD | 08.11.00.40 | Installshield | /s /v/qn | 3.5 |
| StormCAD | 08.11.00.34 | Installshield | /s /v/qn | 3.5 |
| StormCAD | 08.11.00.24 | Installshield | /s /v/qn | 3.5 |
| StormCAD | 08.09.081.00 | Installshield | /s /v/qn | 2.0 |
| StormCAD | 05.06.014.00 | Installshield | /s /v/qn | 1.1 |
| StormCAD | 05.06.012.00 | Installshield | /s /v/qn | 1.1 |
| StormCAD | 05.06.007.00 | Wise | /s | |
| SewerCAD | 08.11.05.113 | 7Zip/Wix | /gm2 /ai | 4.5.1 |
| SewerCAD | 08.11.05.58 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| SewerCAD | 08.11.04.54 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| SewerCAD | 08.11.03.84 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.03.83 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.03.77 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.02.75 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.02.49 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.02.46 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerCAD | 08.11.00.52 | Installshield | /s /v/qn | 3.5 |
| SewerCAD | 08.11.00.48 | Installshield | /s /v/qn | 3.5 |
| SewerCAD | 05.06.014.00 | Installshield | /s /v/qn | 2.0 |
| SewerCAD | 05.06.011.00 | Installshield | /s /v/qn | 1.1 |
| SewerCAD | 05.06.008.00 | Wise | /s | |
| SewerGEMS | 08.11.05.113 | 7Zip/Wix | /gm2 /ai | 4.5.1 |
| SewerGEMS | 08.11.05.58 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| SewerGEMS | 08.11.04.54 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| SewerGEMS | 08.11.03.84 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.03.83 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.03.77 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.02.75 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.02.49 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.02.46 | IEpress/Wix | /q:a | 3.5 SP1 |
| SewerGEMS | 08.11.01.21 | Installshield | /s /v/qn | 3.5 |
| SewerGEMS | 08.11.00.08 | Installshield | /s /v/qn | 3.5 |
| SewerGEMS | 08.09.26.17 | Installshield | /s /v/qn | 2.0 |
| SewerGEMS | 08.09.025.00 | Installshield | /s /v/qn | 1.1 |
| CivilStorm | 08.11.05.113 | 7Zip/Wix | /gm2 /ai | 4.5.1 |
| CivilStorm | 08.11.05.58 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| CivilStorm | 08.11.04.54 | 7Zip/Wix | /gm2 /ai | 3.5 SP1 |
| CivilStorm | 08.11.03.84 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.03.83 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.03.77 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.02.75 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.02.65 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.02.62 | IEpress/Wix | /q:a | 3.5 SP1 |
| CivilStorm | 08.11.01.36 | Installshield | /s /v/qn | 3.5 SP1 |
| CivilStorm | 08.11.00.08 | Installshield | /s /v/qn | 3.5 |
| CivilStorm | 08.09.26.17 | Installshield | /s /v/qn | 2.0 |
| CivilStorm | 08.09.023.25 | Installshield | /s /v/qn | |
| CivilStorm | 08.09.20.09 | Installshield | /s /v/qn | |
| PondPack | 08.11.01.56 | IEpress/Wix | /q:a | 3.5 SP1 |
| PondPack | 08.11.01.54 | IEpress/Wix | /q:a | 3.5 SP1 |
| PondPack | 08.11.01.51 | IEpress/Wix (older) | N/A | 3.5 SP1 |
| PondPack | 10.01.04.00 | Installshield | /s /v/qn | 1.1 |
| FlowMaster | 08.11.01.03 | Installshield | /s /v/qn | 2.0 |
| FlowMaster | 08.11.00.03 | Installshield | /s /v/qn | 2.0 |
| FlowMaster | 08.01.071.00 | Installshield | /s /v/qn | 1.1 |
| FlowMaster | 08.01.068.00 | Installshield | /s /v/qn | 1.1 |
| FlowMaster | 08.01.067.00 | Installshield | /s /v/qn | 1.1 |
| CulvertMaster | 03.03.00.04 | Installshield | /s /v/qn | 2.0 |
| CulvertMaster | 03.02.00.01 | Installshield | /s /v/qn | 2.0 |
| CulvertMaster | 03.01.010.00 | Installshield | /s /v/qn | 2.0 |
| CulvertMaster | 03.01.009.00 | Installshield | /s /v/qn | 1.1 |
| CulvertMaster | 03.01.003.00 | Wise | /s |
If you try the silent installation and the product does not appear to install, the installation log files may have information that is useful to solver the issue. You can send the installation log files to Bentley's Global Technical Support for review.
However, if there is an issue, there are a few things that you can try. First, try downloading a new version of the installation file. If that doesn't help, check you security software logs to see if the installation file was in the report. Adding the file to an exception list can help. If you are using a third-party program called BeyondTrust, this has also been known to have issues related to installation. This link has information related to that: Unable to choose individual applications during installation of OpenFlows Water, Storm or Sewer.
How can I disable the ArcGIS, Microstation, and AutoCAD integration Option?
Extracting an .msi file from hydraulics and hydrology (OpenFlows) programs
