| Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, HAMMER, WaterCAD | ||
| Version(s): | 08.11.XX.XX, 10.XX.XX.XX |
What is the difference between an efficiency curve and a wire-to-water efficiency curve?
Problem ID#: 52822
The wire-to-water efficiency curve is the overall efficiency curve for the pump whereas, the efficiency curve is a simplified efficiency curve that does not take into account the wire-to-water interaction with the
pump. The differences in the two curves are usually very slight.
