| Product(s): | FlowMaster |
| Version(s): | 08.01.071.00 and later |
| Area: | Installation |
| Original Author: | Terry Foster, Bentley Technical Support Group |
The following error occurs when attempting to open FlowMaster
InvalidOperationException Details
Press Ctrl-C to copy details to clipboard:
System.InvalidOperationException: DragDrop registration did not succeed. ---> System.Threading.ThreadStateException: Current thread must be set to single thread apartment (STA) mode before OLE calls can be made. Ensure that your Main function has STAThreadAttribute marked on it.
at System.Windows.Forms.Control.SetAcceptDrops(Boolean accept)
--- End of inner exception stack trace ---
First, ensure that your antivirus / security software is not interfering with FlowMaster. Check the quarantine or history area, add an exception if needed, or try temporarily disabling it to see if it allows FlowMaster to operate correctly.
Try upgrading to FlowMaster 2025 or higher (25.00.00.982).
Browse to C:\Program Files (x86)\Bentley\FlowMaster. Double-click on the file FlowMaster.starter.exe. If the program launches without issue, point your FlowMaster shortcut to the FlowMaster.starter.exe file in the FlowMaster installation folder, instead of FlowMaster.exe.
Make sure that you installed version 08.01.071.00 of FlowMaster. The below patch will only work with this version. You can download this version from the Bentley SELECTservices.
Make a backup of your existing FlowMaster.starter.exe file. This is located in your FlowMaster install folder.
Download the following patched executable:
ftp://ftp.bentley.com/pub/knowledgebase/attachments/FlowMaster.Starter.exe
Choose to save it to the FlowMaster install folder.
The program should now open without a problem. Note that you may need to point your shortcut to the FlowMaster.starter.exe file.
You can try uninstalling and then re-installing the .NET runtime. Our software as of April 1st, 2014 uses .NET 3.5. Installing higher version also seem to help as found on this Forum post.
