| Product(s): | HAMMER |
| Version(s): | 10.03.05.03 and 10.03.05.05 |
| Area: | Installation |
CONNECT Edition Update 3 version 10.03.05.XX of HAMMER introduces improvements and features to help you be more successful.
Note: this was initially released as version number 10.03.05.03 and later re-released as version 10.03.05.05 to fix the issue mentioned in this article.
Stability enhancements and fixes to reported issues
Integration with MicroStation CONNECT Edition is now supported with this release of HAMMER. If there are issues related to integration, see this link: Troubleshooting MicroStation integration.
Compatible Operating Systems
Supported Platforms:
Models saved in build 10.03.04.XX of HAMMER can be opened in other 10.03.XX.XX releases. Older model files can be opened in the latest version without issue.
See also: Model backward / forward compatibility
As with all new versions, this release of HAMMER includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
Downloading OpenFlows / Hydraulics and Hydrology Software
Cumulative patch set information
Set up notifications for new versions and patch set releases
