| Product(s): | WaterCAD, WaterGEMS, HAMMER, SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack, CulvertMaster | ||
| Version(s): | 08.11.XX.XX, 10..XX.XX.XX | ||
| Area: | Help and Documentation |
For the OpenFlows products, the user's manual (user guide) can be found in the root of the installation folder, in PDF form. It contains the same content as the in-program Help. For example, for WaterCAD, it will be located in installation folder. It is different for different versions.
If you are a new user learning the software, you can find a wealth of other learning resources here:
| WaterCAD / WaterGEMS | New User Learning Resource Guide |
| HAMMER | New User Learning Resource Guide |
| SewerGEMS | New User Learning Resource Guide |
| SewerCAD | New User Learning Resource Guide |
| StormCAD | New User Learning Resource Guide |
| CivilStorm | New User Learning Resource Guide |
| PondPack | New User Learning Resource Guide |
| CulvertMaster |
The Help documentation (CVM,chm) is what we have at this time. It's located in the installation folder |
