| Product(s): | WaterCAD, WaterGEMS, SewerCAD |
| Version(s): | 08.11.XX.XX and higher |
| Area: | Modeling |
Why does the system head curve generated by the program looks different than one generated from hand calculations? Why does the curve not look parabolic sometimes?
It is important to understand that there are subtle differences between how WaterGEMS, WaterCAD, and SewerCAD computes system head curves versus how an engineer would compute a them by hand.
When one manually compute a system curve for a transmission line, (s)he generally ends up with a parabolic system curve (assuming you are using the Darcy-Weisbach formula where headloss is proportional to v^2). The process is pretty straight forward provided you have a single pipe, only one pump station, and no intermediate demands. But if you add some of those complications the calculations get much more difficult.
With WaterGEMS and WaterCAD, you can easily examine more complex systems - systems which would be practically impossible to solve by hand (e.g. multiple pumps, loops, demands, tanks, etc). WaterCAD/GEMS does this by computing the hydraulics for the network once for each point on your system head curve, as if it were a regular WaterCAD simulation. For example, say that you want a system head curve containing 5 points from 100 to 500 L/s (plus a point at 0 L/s), as shown below. WaterCAD would compute the model 6 times; once where there was no flow at the pump location, once when there was 100 L/s at the pump location, once where there was 200 L/s at the pump location and so on.
Example System Head Curve:
Flow Head
0.00 29.7
100.00 30.5
200.00 32.6
300.00 36.3
400.00 41.5
500.00 48.1
Note that this is "at the pump location" because for these calculations WaterGEMS/WaterCAD isn't using any pump information that you may have entered to generate the system head curve. Instead, behind the scenes, the program is merely applying a demand immediately upstream of the pump location and an inflow immediately downstream of the pump location, and then computing the resulting head difference. In other words, the pump is temporarily replaced in the calculation by two 'virtual' (i.e., not really there in your model) nodes. For more information on this process, please see chapter 8.6 ("Generating a System Head Curve") of the Advanced Water Distribution Modeling and Management book.
Now because WaterGEMS/WaterCAD is solving your entire network to work out the system head curve, there are many reasons why your resulting curve might not be parabolic. For example, there could be another pump station in your system which turns off at some point due to a pressure control; or a flow control valve might start to influence the system curve above a certain flow; or the supply of all the system demands might mean flow needs to travel a much longer distance into a storage tank, etc. Even the concept of 'static head' is difficult in a complex network because if you have, say, a second pump station in the network, your 'static' head at the first pump station will most likely depend on whether the second pump is on or off! But in the end, what the program gives you is a real system head curve because, according to your model, it is truly the head a pump would need to provide to deliver a certain flow.
Furthermore, in a "closed system" in WaterCAD or WaterGEMS where the system demands are supplied and no storage tanks exist, a system head curve is invalid, because there can only be one value of flow that the pump can pass - the value equal to the sum of all demands. In this case, the system head curve will not be valid except for that singular flow point and it's corresponding head. See: System head curves with no downstream storage
The most common reason for the pump curve not to be parabolic is water consumption between the pump and the downstream tank. When this consumption occurs, it lowers the system head at low flow. In fact, if the consumption between the pump and tank is greater than the pump output(such that flow goes from the tank toward the pump), then there is an inflection point in the pump curve. If you want to check this out manually, put a single large demand between the pump and tank. WaterGEMS and WaterCAD, of course, handles this automatically.
If you want to learn more about pump curves, obtain a copy of the paper:
Ormsbee, L. and Walski, T. "Developing System Head Curves for Water Distribution Systems," Journal AWWA, Vol. 81, No. 7, July 1989
Understanding System Head Curves in WaterGEMS, WaterCAD, and SewerCAD
