| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
WaterSight can connect to any telemetry system (SCADA, Dataloggers, etc) to bring sensor time series data. This data is typically available at 15 minutes or smaller time steps. For more information about data connection requirements, take a look at this article - Sensor Data Acquisition Requirements.
On the top right of the page, select for which elements to display graphs:
| Sensor Overview (this page) | |
| Zone Overview | |
| Large Customers Overview |
The Sensor Overview pages show side by side graphs of every sensor (configured in the Sensor Administration page). The main goal is to provide an at-a-glance indication if "patterned" variables lie within the expected range of values​. Particularly useful to quickly spot any anomalies (that can represent bursts, leaks, tank overflows, pressure problems, maintenance works, etc) in real time.
By default up to 6 graphs are displaying chart readings of the past 24 hours and a forecast of 6 hours. The time range period considered for all graphs can be changed by pressing the calendar icon button .
The grey band on each chart represents the pattern confidence bands computed from last two months of historical sensor readings. A pattern corresponds to an expected behavior for the sensor. In OpenFlows WaterSight pattern confidence bands are computed for each sensor using advanced data analytics (statistic equations together with machine learning techniques to remove outliers or bad data). For these calculations several considerations such as the data history for each specific sensor as well as the distinction between week-day and weekend are taking into consideration.
A wide grey band indicates that there were large variations in the sensor values during the time period for which the bands were developed. A narrow band indicates that the sensor value has been relatively constant at that time of day for the time period (hour and day of week) for which the bands were developed.
Real raw values are re-sampled in every 15 minutes and are represented as a black, red or orange circles. Whenever real data (re-sampled) goes outside the pattern confidence bands (above percentile 95 or below percentile 5 of the pattern), an outlier is identified and the value is color coded with a red circle.
If there is not enough historical data to compute the pattern confidence bands an informative message is displayed, and only real (re-sampled) values are shown. Clicking on this message removes the message.
Patterns can be customized by the user in the Administration page, under Settings > Pattern.
Note: Sensors will display in descending priority. Highest priority first. Sensors with a priority of 0 will not be displayed in the overview. The priority of each sensor is defined at the Sensors configuration, in the administration page.
Filters the grid of sensors to the ones containing the word fragment typed in (case-insensitive) and is also limited by the property selected under Measurement.
Filters the grid of sensors to the ones with matching measurement type.
See the sensors displayed by user defined groups. User defined groups or Tags are defined in the Sensor Configuration, under Administration. Please note that if no Tags are defined under sensors administration, this field does not appear.
Press calendar icon as well as the left and right arrows to select different periods for the overview time series that are displayed, including any historical period. Once selected, all the overview graph dates will updated accordingly with the selection.
Click on the visibility button, under the graphic tools, to add model results (represented with a blue line) and raw data (represented with a green line) in the graphs. More information can be found below, under graphic tools.
Use the graphic toolbar to control the display of the charts shown on the sensor card, with the possibility to add additional information:
| Entry | Description |
Turn on/off: - Legend of the graphs - Signal data - Events highlighted in the graphs (with the additional flexibility to display only active events or all events) - Statistics (or patterns) - Current time marker - Raw data Raw data is represented with a green line and corresponds to the original time series data that is being collected from the origin data sources into WaterSight, without any type of treatment and processing. And usually with a very short time step (every minute or every 5 minutes). More information about raw data cleaning and resampling can be seen in this article - Patterns and Demand Forecast calculation - Model results Model results are displayed with a blue line and correspond to the values obtained from the real time hydraulic model that is running in WaterSight for the sensors location. To have the model results displayed here it is required to have SCADA signals and SCADA elements configured in the uploaded WaterGEMS model and mapped to the right model elements. More information can be found here - Preparing WaterGEMS model for real time simulation in WaterSight. |
Turn on/off "full y-Range option" in graphs and define the time period for the graphs (last 6 hours, last 12 hours, last day, last two days, last three days, last week) |
| Download data that is being displayed on graphs (PNG or CSV format) | |
More graph configurations: spike lines, data tooltip and font size.
Displays the Sensor Name and the color-coded status at the top. Click the Sensor Name to navigate the Sensor Details.
Located at the bottom left corner of the page, it allows to specify rate at which pages are automatically changed. Dropdown is displayed when more than 1 single page is available. Cycling can be deactivated or set to one of the offered rates.
Located at the bottom of the page, it divides the set of available sensors into "pages" and controls which page is being displayed. The number of charts per page can be picked from the "Charts per Page" dropdown.
At the bottom right corner of the page, the user can select the number of charts to as grid on the page
| Entry | Grid Size |
| 6 charts per Page | 3 x 2 |
| 9 charts per Page | 3 x 3 |
| 12 charts per Page | 4 x 3 |
| 15 charts per Page | 5 x 3 |
Note: Clicking the sensor card title navigates to the Sensor Detail of that specific sensor.
Sensor Data Aquisition Requirements
