| Product(s): | StormCAD, CivilStorm, SewerGEMS, SewerCAD | |
| Version(s): | 10.00.00.40 and earlier | |
| Environment: | N\A | |
| Area: | Data Input/Model Creation | |
The following error message is generated when trying to import an InRoads SDB file into a storm/sewer product:
- "Item has already been added. Key in dictionary: 'DUMMY INLET' Key being added: 'DUMMY INLET'".
- "Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index"
- This issue has been resolved in a patch for version 10.00.00.40, and fixed in version 10.00.00.45 and later of storm/sewer products. It is recommended that you download the latest build of the storm/sewer products. This link has instructions on downloading the products.
- This may occur if the Inroads network has one or more instances of a pipe with two upstream pipes coming into it, but with the upstream node not set to "Y_JUNC". Correct this and the file should import.
Opening an InRoads Storm and Sanitary drainage database in Storm/Sewer products
Setting units for data import and export (LandXML, Inroads, etc)
