| Product(s): | Bentley WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, StormCAD, HAMMER, WaterCAD |
| Version(s): | 08.11.XX.XX, 10.XX.XX.XX |
How do I filter a column in my flex table using a custom query that retrieves all records with a <None> attribute?
All you need to do is set up your query to use "Is Null". For example, If I wanted to filter the zone column on all records that are set to <none> my custom query would read as follows:
Physical_Zone Is Null
