WaterSight - Sensor Status
Product(s):WaterSight
Version(s):10.00.
Area:Documentation
Select how to display the Sensors
 Sensor Status Map (this page)
 Sensor Overview
This page displays a color coded status of all configured sensors on a map.
The color coding is based on time delay of the lastest value found in the Sensor's database and its Communication frequency.
Layers
Use the layers option located on the top of the map to enable or disable additional geospatial information as well as the 3D context.
Any GIS information that is uploaded in WaterSight (through shapefile upload in the GIS administration page) will be here displayed. The 3D context includes the 3D terrain, the 3D building outlines. Both 3D terrain and 3D building outlines capabilities are automatically available for the region of interest. Building outline options only becomes available after you enabled the 3D terrain. To activate the 3D view, please use the shift + scroll button the mouse or use the rotate button located on the top right side to rotate the view  . More information here.
Sensor Status
Sensors listed on the right side menu are color coded according to the following:
CategorySymbolDescription
No Data (Now – LastInstantInDB) > 4 x MaxLagTime
Partial data (Now – LastInstantInDB) < 4 x MaxLagTime
OK (Now – LastInstantInDB) < 2 x MaxLagTime
Where MaxLagTime is
15min + Sensor communication Frequency + Sensor Registration Frequency
Last Instant in DB corresponds to the last time step for which values were registered in the database for each given sensor. This time can be seen under Admin >> Sensors, by looking at Last Instant in DB column. Sensor communication frequency and registration frequency are also defined under Admin >> Sensors
Selected Sensor
When clicking a sensor on the map or selecting a sensor from the list located on the right side menu, a sensor chart with sensor reading for the previous 24 hours is shown below the map together with more information on the right side menu:
ID: The SCADA signal tag name associated with the sensor.
Value: The sensor value of the latest signal reading.
Latest: The timestamp of the latest signal reading.
By clicking in Open Details the user will be redirected to the sensor details page.
Sensor Graph
The pattern confidence bands are represented by a grey band, while real (re-sampled 15 minutes) values are represented as a black, red or orange circles. Whenever real data (re-sampled) goes outside the pattern confidence bands (above percentile 95 or below percentile 5 of the pattern), an outlier is identified and the real value is color coded with a red circle. The user can drill in to the graph details by directly clicking on the sensor name located above the graph.
Search
Clicking in the   icon located on the right side menu to search for a specific sensor. Restricts the displayed sensors to the text fragment entered into the search field.
Filter
Clicking in   icon located on the right side menu to filter sensors. It is used to control the way the sensor list is displayed.
Sort ByDescription
AlphabeticSorts the list of sensors ascending in alphabetical order
StatusGroups the list by status and sorts within groups in alphabetical order
MeasurementGroups the list of sensors by their measurement and sorts within the group in alphabetical order
StatusDescription
No dataSensors report significant delay
Partial dataSensor reporting moderate delay
OKSensor reporting within expected Delay
Measurement: The sensor measurement is configured under Sensor Configuration, under Administration.
Tag: see the sensors displayed by user defined groups. User defined groups or Tags are defined in the Sensor Configuration, under Administration.
Controls
Use the map controls to control the visibility of pipes and to define the assessment period.
 Description
PipesTurn on or off pipes.
Status
Define the period which sensor status are evaluated. By default sensor status are evaluated considering last 24 hour period, but user can choose to assess sensor status in the last 3 hours or in the last 7 days.
If you are looking for more information about WaterSight, please go to OpenFlows WaterSight TechNotes and FAQ's.
