| Product(s): | SewerGEMS, SewerCAD, CivilStorm, StormCAD |
| Version(s): | 08.11.XX.XX and higher |
| Area: | Modeling |
What are the differences between the numerical solvers?
When should I use StormCAD instead of CivilStorm? Or when should I use SewerCAD instead of SewerGEMS?
It depends of the type of sanitary system you want to model: wastewater networks, stormwater networks or combined networks). Also depending on the scale, complexity of control structures and pumping systems you will want to properly model some hydraulic or hydrologic behaviors that are relevant to your analysis.
Calculating the hydraulics of wastewater and stormwater collection systems can be very difficult and complex,. These systems have constantly changing conditions–from partially full pipes to complex control structures used for the pumping system.
For this reason, our OpenFlows solutions offer 5 numerical solvers, that enable a wide range of methods to simulate different sanitary networks and hydraulic behaviors.
The SewerCAD GVF-Convex solver uses convex routing and a gradually varied flow profile for design and analysis of sewer networks including mixed gravity and pressure flow, which is generally recommended for wastewater networks
The StormCAD GVF-Rational solver analyzes or designs drainage system using the Rational Method for peak flow conditions based on peak rainfall intensity, because of that it is not recommend for large drainage basins.
CivilStorm is a superset of StormCAD and adds 3 solvers to its functionality, the SWMM (Explicit Solver), Dynamic Wave (Implicit Solver) and the 2D solver, that allows larger and more complex hydraulic and hydrologic stormwater systems behaviors.
SewerGEMS is a superset of SewerCAD and CivilStorm, including all its functionality and the ability of simulating combined sewers and ArcGIS integration support.
NOTE : Each solver supports different calculation methods for various individual network components. See more in articles such as these:
The SewerCAD application (and the GVF Convex numerical solver in SewerGEMS) is best used in systems that have complicated pumping, pressure sewers, and only need to use extended period simulation convex (EPS) routing as opposed to fully dynamic routing. SewerCAD should also be used if you need to perform a constraint-based design or if you need to run a steady state simulation, such as for a peak flow analysis with Extreme Flow methods.
SewerCAD can be thought of as a bread-and-butter package that delivers conventional design and capacity analysis. Municipal-scale master planning is certainly part of it but serves very well in site/civil arena as well. Routing is hydrologic with conventional back-water dominant hydraulics. Gravity analysis is complete with well-accepted state-of-the-practice hydraulic grade analysis with form losses. Diversions or splits are handled in explicit ways. I&I, similarly, is modeled using an array of fundamental and appropriate simplifying models.
On the other hand, the SewerGEMS/Civlstorm applications layer into the mix solvers for dynamic wave simulation (implicit and explicit (SWMM), with ArcGIS integration support. So, if you have challenging cross-connections, loops or dynamic surcharging and ponding, this gives you the capabilities of EPA SWMM along with Bentley's own implicit solver. SewerGEMS (Implicit or Explicit Dynamic numerical solvers) is best for analyzing existing problematic systems, where catchment rainfall-runoff calculations are required, or dynamic wave solutions are needed (if required by the reviewer or by way of the complicated nature of the particular network) or if you must work inside the ArcGIS platform.
SewerGEMS can handle complex things like control structures, diversions (without having to enter a diversion rating curve required in SewerCAD/GVF Convex solver) or ponds. Long term continuous simulations would be done using the Explicit solver in SewerGEMS. The "solver" refers to the type of numerical finite difference solution used to solve the St. Venant equations, which describe unsteady one-dimensional, free surface flow. The software contains two different solvers::
Implicit solver - Uses a four-point implicit finite difference solver to find the numerical solutions for the hydrodynamic Saint-Venant equations. This solver is based on the National Weather Service FLDWAV model. The implicit solver tends to be more stable with pumping situations (for example using a timestep of 0.01 hr - 0.005 hr)
Explicit (SWMM) solver - Uses the solver from the EPA Stormwater Management Model version 5 (SWMM). The results from this solver should exactly match the results from SWMM 5. The explicit solver tends to be more stable with fast changing areas such as ponds or control structures where the flow or elevation changes quickly over multiple time steps.
Inflow hydrographs are also handled differently by the two engines. The implicit engine interpolates flows between the final flow in the hydrograph and the end time. The SWMM engine assumes that all flows after the final inflow point are zero.
*Note: If a catchment is using the EPA SWMM runoff method and not using the default infiltration method specified in the SWMM calculation options then neither hydrology or network will calculate. If you are not using the EPA SWMM runoff method, then any combination of other runoff methods can be used.
Note: Starting with the CONNECT Edition Update 2 release of SewerGEMS and CivilStorm, you now have the option to select and use either the Bentley-enhanced version of the SWMM solver or the straight SWMM solver also found in EPA-SWMM. You can select this from the properties of the Calculation Option.
GVF-Convex (SewerCAD) solver is not intended to handle overflow situations such as a case where you want to analyze a problematic existing system. When an overflow condition arises with the GVF Convex solver, the HGL is reset to the rim for an overflow condition. However, the dynamic solvers in SewerGEMS (Implicit and Explicit SWMM solvers) do handle overflow, as they are intended for situations like this (problematic existing systems and/or complex situations). SewerGEMS Implicit and Explicit solvers automatically calculate the overflow using the weir equation.
So, SewerGEMS differentiates in the market as being a singular, "top of the line" tool that will carry the engineer though all stages of design and analysis from conventional capacity and constraint based design of pipe networks into complex hydraulics of combined-sewer systems. SewerGEMS will handle both storm and sanitary models. Importantly, if you have any old StormCAD, SewerCAD or CivilStorm files they can all be loaded into SewerGEMS and brought cleanly ahead.
Note: Currently the StormCAD numerical solver is included with CivilStorm, so CivilStorm has all of the functionality of StormCAD included, by way of selection of GVF Rational as the active numerical solver.
The StormCAD product (and the GVF Rational Solver in SewerGEMS and CivilStorm) uses the rational method to analyze or design a system under peak flow conditions based on peak rainfall intensity, while the other solvers in CivilStorm and SewerGEMS such as the Implicit or Explicit, takes rainfall hyetographs (rain vs. time) and develops hydrographs (flow vs. time) for each pipe and routes the flows dynamically. If you are studying a small area where only peak flow is of interest, or if you need to design a system based on the standard rational method, then StormCAD or the StormCAD solver (GVF Rational) should be adequate. If you are working on a large area where hydrograph routing and storage are significant, where you need to use a dynamic solver, or if you need to otherwise analyze more complex effects such as flooding and controls structures, then the Implicit and Explicit solvers in CivilStorm (or SewerGEMS) is what you need.
If you get involved with combined sewers where rain and sanitary sewage is carried in the same pipe, we recommend you use one of the dynamic solvers in SewerGEMS.
When flow paths are uncertain, like those observed on the surface runoffs, water can travel in various directions before reaching the lowest point, the 2D modeling becomes advantageous.
Compared to the other 1D Solvers (GVF - Convex, GVF -Rational, Implicit and Explicit solvers), it yields superior results when dealing with overflowing structures (e.g., manholes) or assessing flooded areas. This solver handles complex systems, cross-connections, loops, manhole overflows, surcharge, and unsteady non-uniform flow.
The new 2D solver employs the 2D Saint-Venant equations to determine water depth and velocity on a gridded surface and 1D Saint-Venant Equations for the hydraulic behaviour inside the sanitary systems (Conduits, tubes, channels, etc..).
Coupling 1D network elements with the 2D surface, it is possible to simulate interactions between surface and network, allowing assessment, analysis, simulation, and design of infrastructure considering flood wave propagation.
OpenFlows SewerGEMS Solvers Part 1: Choosing the Right Solver for Your Stormwater Network
2D or not 2D–Choosing the Best Type of Simulation in OpenFlows
