| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
The Tanks module allows the user to:
- Quickly assess real time levels in each tank;
- Compare real time levels with minimum and maximum levels defined;
- Understand trends in tank operation;
- Compare tank variables (hydraulic grade, level and percent full) between other tanks;
- Calculation of turnover time and mix performance ratio for each tank;
The Tanks module includes the following sub-menus:
Topics
