| Product(s): | OpenFlows Water (WaterCAD, WaterGEMS, HAMMER) OpenFlows Sewer (SewerGEMS, SewerCAD) OpenFlows Storm (CivilStorm, StormCAD, PondPack) OpenFlows Hydraulic Toolset (FlowMaster, CulvertMaster) |
| Area: | Installation |
This article documents platform integration (AutoCAD, MicroStation and ArcGIS) and operating system compatibility for each OpenFlows product version.
A Note on Hardware / System Requirements
For hardware requirements (RAM, CPU, Video card), refer to the Readme.PDF file included in the installation folder of your Bentley OpenFlows product. In general, hardware requirements are highly dependent on the size and complexity of the hydraulic model. The more elements and more complexity in the model and the longer the simulation duration, the more memory it will take up and the more sensitive the performance will be to the speed of the CPU. Since OpenFlows products use a 2D drawing pane, they are generally not graphics intensive. For more information, see How to increase model performance / reduce run time.
To download the latest versions, please see the following article: Downloading OpenFlows / Hydraulics and Hydrology Software.
OpenFlows Water
WaterCAD & WaterGEMS
| Version |
26.00.00.514 & 26.00.00.532 (2026) |
24.00.03.22 (2024) |
24.00.02.20 (2024) |
24.00.01.05 & 24.00.01.12 (2024) |
24.00.00.27 (2024) |
23.00.00.16 & 23.00.00.19 (2023) |
10.04.00.106 & 10.04.00.107 & 10.04.00.108 |
10.03.05.03 & 10.03.05.05 |
10.03.04.05 |
10.03.03.72 |
10.03.02.75 |
10.03.01.08 |
10.03.00.69 |
10.02.03.06 |
10.02.02.06 |
10.02.01.06 |
10.02.00.43 |
10.01.01.04 |
10.01.00.72 |
10.00.00.55 (CONNECT Ed.) |
10.00.00.49 & 10.00.00.50(CONNECT Ed.)
08.11.06.58 (SS6) & 08.11.06.113 |
08.11.05.61 (SS5) |
08.11.04.57 08.11.04.58 (SS4) |
08.11.04.50 (SS4) |
08.11.03.16 08.11.03.17 08.11.03.19 (SS3) |
08.11.02.31 (SS2) |
08.11.01.32 (SS1) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-2 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Sep-27 / 2023-Nov-24 | 2022-Sep-8 / 2022-Sep-15 / 2022-Sep-26 | 2021-Sep-7 | 2021-Jul-1 | 2021-Apr-6 | 2020-Nov-12 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Dec-22 | 2017-June-16 | 2016-Oct-12 / 2016-Nov-28 | 2015-Aug-27 / 2016-Feb-10 | 2014-Aug-4 | 2013-Jul-1 | 2013-May-6 | 2011-Jul-8 | 2010-Nov-24 | 2009-Oct-26 |
| O/S compatibility |
Windows 11, 10, Server 2019/2022 |
Windows 10, 8.X, Server 2012 |
Windows 10, 8, Server 2008/2012 |
Windows 10, 8, 7, Server 2008/2012 |
Windows 10, 8, 8.1, 7 SP1 (32 & 64-bit for all) |
Windows 7, SP1 |
Windows 8.X, 7, Vista
Note: XP no longer supported. |
Windows 7, 8, Vista, XP, 2008, Server 2003
Windows XP, 7, Server 2003, Vista, Server 2008 | Windows XP, 7, Server 2003, Vista, Server 2008 | Windows XP, 7, Server 2003, Vista, Server 2008 | Windows XP, 7, Server 2003, Vista, Server 2008 |
| Supported AutoCAD Versions. (Alternatives here.) |
2025, 2026 (64-bit) NOTE: 2026 update not compatible) | 2024, 2025, 2026 (64-bit) | 2024, 2025 (64-bit) | 2023, 2024 (64-bit) | 2023, 2024 (64-bit) | 2023, 2024 (64-bit) | 2022, 2023, 2024* (64-bit) *contact Support |
2019 (32/64-bit), 2020, 2021, 2022 (64-bit) | 2019 (32/64-bit), 2020, 2021, 2022 | 2019 (32/64-bit), 2020, 2021 (64-bit) | 2019 (32/64-bit), 2020, 2021 (64-bit) | 2019 (32/64-bit), 2020, 2021 (64-bit) | 2018, 2019 (32/64-bit), 2020 (64-bit) | 2018, 2019 (32/64-bit), 2020 (64-bit) | 2018, 2019 (32/64-bit), 2020 (64-bit) | 2018, 2019 (32/64-bit), 2020 (64-bit) | 2018, 2019 (32/64-bit) | 2017, 2018, 2019 (32/64-bit) | 2018, (32/64-bit), 2017(32/64-bit), | 2018 (32/64-bit), 2017(32/64-bit), 2016 (32/64-bit) |
2017(32/64-bit), 2016 (32/64-bit) | 2016 (32/64-bit)2015 (32/64-bit) | 2015 (32/64 bit) 2014 (32/64 bit) |
2014 (32/64 bit) 2013 (32/64 bit) 2012 (32/64 bit) |
2012 (32/64 bit) 2011 (32 bit) 2011 (64 bit)* |
2011 2010* | 2010 2009* |
Certified MicroStation versions. |
2023, 2024, 2025, 2026 |
2023, 2024, 2025 (see this for 2024) |
2023, 2024 (see this for 2024) |
2023, CONNECT Edition (see this for 2024) |
2023, CONNECT Edition |
CONNECT Edition |
V8i SS10, CONNECT Edition |
V8i SS10 |
V8i SS10 |
V8i SS10 |
V8i SS10 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
8.11.7.x and 8.11.9.x |
8.11.7.X & 8.11.9.X |
08.11.09.459(SS4) | 08.11.09.357 (SS3) 08.11.07.443 (SS2) |
08.11.09.xx (SS3) 08.11.07.xx (SS2) |
8.11.7.443 (SS2) 08.11.09.xx (SS3) |
8.11.7.443 (SS2) | 8.11.7.x |
| Supported ArcGIS Pro and ArcMap versions (WaterGEMS) |
ArcGIS Pro 3.x (min 3.1, max 3.6) Details here |
ArcGIS Pro (min 3.1, tested up to 3.5) Details here |
ArcGIS Pro 3.1+ Details here |
ArcGIS Pro 3.1+ |
ArcGIS Pro 2.8.0.29751 through 2.9.X (details here) ArcMap 10.8.X (Details here) |
ArcGIS Pro 2.6-2.8 (see details here), ArcMap 10.8.X (Details here) |
ArcGIS Pro 2.6&2.7 (see details here), ArcMap 10.8.X (Details here) |
ArcGIS Pro 2.6 (see details here), ArcMap 10.8.X (Details here) |
ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.5.X (see details here) | ArcMap 10.5.X (see details here) | ArcMap 10.4.1 (see details here) | ArcMap 10.3.x (see details here) | ArcMap 10.3.X (via patch) (see details here) | ArcMap 10.2 (see details here) |
ArcMap 10.1 SP1 (see details here) | ArcMap 10.0 (see details here) | ArcMap 10.0 (see details here) | ArcMap 9.3 SP1 (see details here) |
| Supported ProjectWise versions |
2025, 2024, 2023, CONNECT Ed. |
2023, 2024, CONNECT Ed. |
2023, CONNECT Ed., V8i SS3/SS4 |
CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i, V8 XM | V8i, V8 XM | V8i, V8 XM | V8i, V8 XM | V8i, V8 XM |
| Licensing Method | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver |
| Version of .NET needed | 4.8 | 4.8 | 4.8 | 4.8 | 4.8 | 4.7.2 (build 16) or 4.8 (build 19) | 4.7.2 | 4.7.2 | 4.7.2 | 4.7.2 | 4.6.2 | 4.6.2 | 4.6.2 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.5.1 | 3.5 SP1 (08.11.06.58), 4.5.1 (08.11.06.113) | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 + SP1 |
HAMMER
| Version |
10.04.00.106 & 10.04.00.107 |
10.03.04.05 |
10.03.03.72 |
10.03.02.75 |
10.03.01.08 |
10.03.00.69 |
10.02.03.06 |
10.02.02.06
10.02.01.06 | 10.02.00.43 | 10.01.01.04 | 10.01.00.72 | 10.00.00.55 (CONNECT Ed.) | 10.00.00.49 (CONNECT Ed.) |
08.11.05.61 |
08.11.04.57 |
08.11.04.50 (SS4) |
08.11.02.31 (SS2) | 08.11.01.32 (SS1) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-2 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Sep-27 / 2023-Nov-24 | 2022-Sep-8 / 2022-Sep-15 | 2021-Sep-7 | 2021-Jul-1 | 2021-Apr-6 | 2020-Nov-12 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Dec-22 | 2017-June-16 | 2016-Oct-12 | 2015-Aug-27 | 2014-Aug-4 | 2013-Jul-1 / 2013-Nov-5 | 2013-May-6 | 2011-Jul-8 | 2010-Dec-7 | 2009-Oct-26 |
| O/S compatibility | Windows 11, 10, Server 2019/2022 | Windows 11, 10, Server 2019/2022 | Windows 11, 10, Server 2019/2022 | Windows 11, Windows 10, Server 2019/2022 | Windows 11, Windows 10, Server 2019/2022 | Windows 11, Windows 10, Server 2019/2022 | Windows 11, Windows 10, Server 2019/2022 | Windows 10, Windows 8.X, Server 2012 | Windows 10, Windows 8.X, Server 2012 | Windows 10, Windows 8.X, Server 2012 | Windows 10, Windows 8, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7,Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7, Server 2008/2012 | Windows 10, Windows 8, Windows 7 (32 & 64-bit for all) | Windows 10, Windows 8, Windows 7 (32 & 64-bit for all) |
Windows 7, |
Windows 7, 8, Server 2003, Vista, Server 2008 Note: XP no longer supp. |
Windows XP, 7, 8, Server 2003, Vista, Server 2008 |
Supported AutoCAD Versions |
2022, 2023 |
2019, 2020, 2021, 2022 (32/64-bit) |
2019, 2020, 2021 (32/64-bit) |
2018, 2019, 2020 (32/64-bit) |
2018 (32/64-bit), |
2017 (32/64-bit), 2016 (32/64-bit) |
2016 (32/64-bit) 2015 (32/64-bit) |
2012, 2013, 2014 (32/64 bit)
2012 (32/64 bit)2011 (32/64 bit) | 2011, 2010 (only basic testing for 2010) |
2010, 2009 (only basic testing for 2009) |
| Supported ArcMap versions | N/A | N/A (can be enabled) | N/A (can be enabled) | N/A (can be enabled) | N/A (can be enabled) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.5 (see details here) | ArcMap 10.5 (see details here) | ArcMap 10.4.1 (see details here) | ArcMap 10.3.X (see details here) | ArcMap 10.2.1 (10.3.X in patch) (see details here) | ArcMap 10.2 (build .58 only)10.1 (see details here) |
ArcMap 10.1 (see details here) |
ArcMap 10.0 (see details here) | ArcMap 10.0 (see details here) | ArcMap 9.3.1 (see details here) |
| Certified MicroStation versions (Alternatives here.) |
2023, CONNECT Edition | 2023, CONNECT Edition | CONNECT Edition | V8i SS10, CONNECT Edition | V8i SS10 | V8i SS10 | V8i SS10 | V8i SS10 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | 8.11.7.x and 8.11.9.x | 8.11.7.x and 8.11.9.x |
08.11.09.459 |
08.11.09.357 (SS3) 08.11.07.443(SS2) |
08.11.07.443 | 08.11.07.443 | 8.11.7.x |
| Supported ProjectWise versions | 2025, 2024, 2023, CONNECT Ed. | 2023, 2024, CONNECT Ed. | 2023, 2024, CONNECT Ed. | 2023, CONNECT Ed., V8i SS3/SS4 | 2023, CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
| Version of .NET needed | 4.8 | 4.8 | 4.8 | 4.8 | 4.8 | 4.7.2 (build 16) or 4.8 (build 19) | 4.7.2 | 4.7.2 | 4.7.2 | 4.7.2 | 4.6.2 | 4.6.2 | 4.6.2 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.5.1 | 3.5 SP1 (06.58), 4.5.1 (06.113) | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 |
OpenFlows Sewer
SewerCAD
| Version |
24.00.03.23 / 24.00.03.27 |
24.00.02.21 (2024) |
24.00.00.26 (2024) |
10.04.00.158 |
10.03.04.53 |
10.03.03.44 |
10.03.02.04 |
10.03.01.08 |
10.03.00.76/77 |
10.02.03.03 |
10.02.02.04 |
10.02.01.04 | 10.02.00.55 | 10.01.01.04 | 10.01.00.70 | 10.00.00.45 (CONNECT Ed.) | 10.00.00.40 (CONNECT Edition) | 08.11.05.113 (SS5 with CC) | 08.11.05.58(SS5) | 08.11.04.54 (SS4) |
08.11.03.84 08.11.03.83 (SS3) |
08.11.03.77 (SS3) |
08.11.02.75 (SS2) |
08.11.02.49 (SS2) |
08.11.02.46 (SS2) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-4 / 2025-Oct-3 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Mar-2 | 2021-Jul-1 | 2021-Feb-22 | 2020-Dec-1 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Nov-17 | 2017-June-16 | 8/18/2016 | 2/10/2016 | 05/08/2015 | 07/15/2013 | 07/15/2013 | 01/17/2013 | 11/07/2011 | 12/16/2010 | 07/01/2010 |
| O/S compatibility |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 7, 8, 10, Server 2008 |
Windows 7, 8, Server 2003, Vista, Server 2008 |
2022, 2023, 2024* |
2018 (32/64-bit), |
2014, 2015, 2016
2015 |
2012, 2013, 2014
2013 |
2011, 2010 | 2011, 2010 |
| Certified MicroStation versions Alternatives here. |
2023, CONNECT Edition | CONNECT Edition | V8i SS10, CONNECT Edition | V8i SS10 | V8i SS10 | V8i SS10 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS3 | V8i SS3 | 08.11.09.357(V8i SS3) | 08.11.09.357 (SS3)08.11.07.443 (V8i SS2) |
08.11.09.357(SS2), 08.11.07.443 (V8i SS3) | 08.11.07.443 (SS2) 08.11.09.357 (V8i SS3) |
8.11.7.x | 8.11.7.x |
| Supported ProjectWise versions | 2025, 2024, 2023, CONNECT Ed. | 2023, 2024, CONNECT Ed. | 2023, 2024, CONNECT Ed. | 2023, CONNECT Ed., V8i SS3/SS4 | 2023, CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | CONNECT Ed., V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i SS3/SS4 | V8i, V8 XM | V8i, V8 XM | V8i, V8 XM |
| Licensing Method | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver |
| Version of .NET needed | 4.8 | 4.8 | 4.8 | 4.8 | 4.8 | 4.7.2 | 4.7.2 | 4.6.2 | 4.6.2 | 4.6.2 | 4.6.2 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.6.1 | 4.5.1 | 4.5.1 | 3.5 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 | 3.5 SP1 |
SewerGEMS
| Version |
24.00.03.23 & 24.00.03.27 |
24.00.01.05 & 24.00.01.12 |
10.04.00.158 |
10.03.04.53 |
10.03.03.44 |
10.03.02.04 |
10.03.01.08 |
10.03.00.76/77/78 |
10.02.03.03 |
10.02.02.04 |
10.02.01.04 | 10.02.00.55 | 10.01.01.04 | 10.01.00.70 | 10.00.00.45 (CONNECT Ed.) | 10.00.00.40 (CONNECT Edition) | 08.11.05.113 (SS5 with CC) | 08.11.05.58 (SS5) |
08.11.04.54(SS4) | 08.11.03.83/84 (SS3) |
08.11.03.77 (SS3) |
08.11.02.75 (SS2) |
08.11.02.49(SS2) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-4 / 2024-Oct-3 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Mar-2 | 2021-Jul-1 | 2021-Feb-22 | 2020-Dec-1 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Nov-17 | 2017-June-16 | 8/18/2016 | 2/10/2016 | 05/08/2015 | 06/03/2014 | 07/15/2013 | 12/19/2012 | 11/07/2011 | 12/16/2010 |
| O/S compatibility |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 10, Windows 8, Windows 7, Server 2008/ 2012 |
Windows 7, 8, 10, Vista, Server 2008, Server 2012 |
Windows 7, 8, Vista, Server 2008 |
Windows XP, 7, 8, Server 2003, Vista, Server 2008 | Windows XP, 7, 8, Server 2003, Vista, Server 2008 | Windows XP, 7, Server 2003, Vista, Server 2008 | Windows XP, 7, Server 2003, Vista, Server 2008 |
| Supported AutoCAD Versions See alternatives here. |
2022, 2023, 2024* |
2018 (32/64-bit), |
2017 (32/64-bit, 2016 (32/64-bit) |
2016 (32/64-bit), 2015 (32/64-bit) |
2014, 2015, 2016
2014, 2015 |
2011, 2012, 2013, 2014 (32/64 bit) |
2013 (32/64 bit)2012 (32/64 bit)2011 (32 bit) | 2012 (32/64 bit), 2011 (32 bit), 2011 (64 bit) |
2011, 2010 |
| Supported ArcGIS Pro and ArcMap versions |
ArcGIS Pro (min 3.1, max 3.6) Details here |
ArcGIS Pro 3.1+ see details here |
ArcGIS Pro 2.8.0.29751-2.9.X (see details here), ArcMap 10.8.X (see details here) |
ArcGIS Pro 2.6.X-2.8.X (see details here), ArcMap 10.8.X (see details here) |
ArcGIS Pro 2.6 (see details here), ArcMap 10.8.X (see details here) |
ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.8.X (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7.1 (see details here) | ArcMap 10.7 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.6.1 (see details here) | ArcMap 10.5 (see details here) | ArcMap 10.5 (see details here) | ArcMap 10.4.1 (see details here) | ArcMap 10.3 (see details here) | ArcMap 10.3 (see details here) | ArcMap 10.2 SP1 (see details here) | ArcMap 10.2 (see details here) | ArcMap 10.1 (see details here) |
ArcMap 9.3.x (see details here) |
| Certified MicroStation versions See alternatives here. |
2023, CONNECT Edition | CONNECT Edition | V8i SS10, CONNECT Edition | V8i SS10 | V8i SS10 | V8i SS10 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS4 | V8i SS3 | V8i SS3 | 08.11.09.357 (SS3) |
08.11.09.357 (SS3) | 08.11.09.357 (SS3)8.11.7.443 (SS2) | 08.11.7.x08.11.09.209 (beta) |
08.11.7.x |
OpenFlows Storm
StormCAD
| Version |
24.00.03.23 (2024) |
10.04.00.158 |
10.03.04.53 |
10.03.03.44 |
10.03.02.04 |
10.03.01.08 |
10.03.00.76/77 |
10.02.03.03 |
10.02.02.04 |
08.11.03.83/84(SS3) |
08.11.03.77(SS3) |
08.11.02.75(SS2) |
08.11.02.38(SS2) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-4 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Mar-2 | 2021-Jul-1 | 2021-Feb-22 | 2020-Dec-1 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Nov-17 | 2017-June-16 | 8/18/2016 | 2/10/2016 | 5/8/2015 | 6/3/2014 | 7/15/2013 | 1/7/2013 |
11/7/2011 |
12/16/2010 |
| O/S compatibility |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 10, 8, Server 2008/R2, Server 2012 |
Windows 10,8, 7, Server 2008, Server 2012 |
Windows 10*, 8, 7, Server 2008, Server 2012 |
Windows 7, 8, 8.1, Vista, Server 2008 |
Windows XP, 7, 9=8, Server 2003, Vista, Server 2008 |
2022, 2023, 2024* |
2014, 2015, 2016
2015 2014
2011, 2010, 2009 |
CONNECT Edition |
V8i SS10 |
V8i SS10 |
V8i SS10 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS4 |
V8i SS3 |
V8i SS3 |
08.11.09.357 (SS3)
08.11.7.443 (SS2) 08.11.09.357 (SS3) |
08.11.7.443 (SS2)8.11.09.357 (SS3) | 8.11.7.443 (SS2)8.11.9.209 (beta) |
8.11.5, 8.11.7 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i, V8 XM |
| Licensing Method | Subscription Entitlement Service | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver | |||||||||||||||||||||
4.6.1 |
4.5.1 |
4.5.1 |
3.5 |
3.5 SP1 |
3.5 SP1 |
3.5 SP1 |
3.5 SP1 |
3.5 SP1 |
CivilStorm
| Version |
10.04.00.158 |
10.03.04.53 |
10.03.03.44 |
10.03.02.04 |
10.03.01.08 |
10.03.00.76/77 |
10.02.03.03 |
10.02.02.04 |
10.02.01.04 | 10.02.00.55 | 10.01.01.04 | 10.01.00.70 | 10.00.00.45 | 10.00.00.40 (CONNECT Edition) | 08.11.05.113 (SS5 with CC) | 08.11.05.58 (SS5) |
08.11.04.54 (SS4) |
08.11.03.77 (SS3) |
08.11.02.75 (SS2) | 08.11.02.65 (SS2) |
| Date Released | 2026-May-19 / 2026-Jul-27 | 2025-Sep-4 | 2025-Jan-23 | 2024-Jul-01 / 2024-Aug-08 | 2024-May-7 / 2024-May-24 | 2023-Mar-2 | 2021-Jul-1 | 2021-Feb-22 | 2020-Dec-1 | 2020-May-28 | 2020-Mar-11 | 2019-Dec-2 | 2019-Sept-20 | 2019-May-2 | 2018-Dec-28 | 2018-May-9 | 2017-Nov-17 | 2017-June-16 | 8/18/2016 | 2/10/2016 | 05/08/2015 | 6/03/2014 | 7/15/2013 | 1/17/2013 | 11/07/2011 | 12/16/2010 |
| O/S compatibility |
Windows 11, |
Windows 11, |
Windows 11, |
Windows 11, |
2022, 2023, 2024* |
2018 (32/64-bit), |
2014, 2015, 2016
2013 (32/64 bit), 2012 (32/64 bit), 2011 (32 bit) |
2012 |
2011, 2010 |
08.11.09.357 (SS3)08.11.07.443 (SS2) |
08.11.09.357(SS3)08.11.07.443 (SS2) |
8.11.7.X 8.11.9.209 (beta) |
8.11.7.X |
V8i, V8 XM |
V8i, V8 XM |
PondPack
| Version |
10.02.00.01 |
10.00.00.02 |
08.11.01.56 |
08.11.01.54 |
08.11.01.51 |
10.01.04.00 |
| Date Released |
2019-Jan-3 |
2018-Aug-8 |
2012-Mar-8 |
2010-Dec-16 |
2009-Oct-26 |
2008-Nov-7 |
| O/S compatibility |
Windows 11, 10, 8/8.1, 7 SP1 (32 & 64-bit for all), |
Windows 10, 8/8.1, 7 SP1 (32 & 64-bit for all), Server 2008/R2, Server 2012
Windows XP, 7, Server 2003, Server 2008, Vista, |
Windows XP, 7, Server 2003, Server 2008, Vista |
Windows XP, Server 2003, Server 2008, Vista | Windows XP, Server 2003, Vista |
2012 (32 bit) 2011 (32 bit)* |
2011 2010 |
2010 2009* |
N/A |
8.5.xx.xx /8.11.7.xx |
8.11.5.x |
N/A |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i SS3/SS4 |
V8i, V8 XM |
| Licensing Method | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver | ||
3.5 SP1 |
3.5 SP1 |
3.5 SP1 | 3.5 SP1 | 1.1 |
FlowMaster
| Version | 25.00.00.982 | 10.03.00.03 | 10.02.00.01 | 10.00.00.02 | 08.11.01.03 | 08.11.00.03 | 08.01.071.00 | 08.01.068 |
| Date Released | 2025-Oct-10 | 2020-Mar-23 | 2019-Jan-3 | 2018-Sep-6 | 2009-Nov-14 | 2008-Aug-27 | 2007-Mar-6 | 2006-Nov-10 |
| O/S compatibility |
Windows 10, 8/8.1, 7 SP1 (32 & 64-bit for all), |
Windows XP, Server 2003, Server 2008, Vista, |
Windows 2000, 2003, XP, Vista |
Windows 2000, XP |
24.x, 23.x, 10.x, V8i SS3/SS4 |
V8i, V8 XM |
V8i, V8 XM |
V8i, V8 XM |
V8 XM |
V8 XM |
| Licensing Method | Subscription Entitlement Service | Subscription Entitlement Service | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver | SELECTserver | SELECTserver / Legacy |
| Version of .NET needed | 4.8 | 3.5 SP1 & 4.6.2 | 3.5 SP1 & 4.6.2 | 3.5 SP1 & 4.6.2 | 2.0 | 2.0 | 1.1 | 1.1 |
CulvertMaster
| Version | 10.03.00.03 | 03.03.00.04 (V8i Generation - see note on Support Policy) | 03.02.00.01 | 03.01.010.00 | 03.01.009.00 |
| Date Released | 2020-Mar-19 | 2009-Nov-5 | 2008-Aug-11 | 2007-Feb-14 | 2005-Dec-6 |
| O/S compatibility |
Windows 11, 10, 8/8.1, |
Windows Vista SP2*, XP SP3 (32/64 bit)*, XP SP2 or later (32/64 bit), Server 2003 SP2 or later, 2008 Server, Windows 7, Windows 2008 Server R2 |
Windows Server 2003 SP1 or later, Server 2003 (64 bit), Windows XP SP2 or later*, Windows XP (64 bit), Windows Vista*, Windows Vista (64 bit) |
Windows 2000*, Windows Server 2003, *Windows XP (32/64 bit)*, Windows Vista (32 bit/64 bit)* |
Windows 2000*Windows XP (32/64 bit)* |
| Licensing Method | Subscription Entitlement Service | SELECTserver | SELECTserver | SELECTserver / Legacy | SELECTserver / Legacy |
| Supported ProjectWise versions | CONNECT Ed., V8i SS3/SS4 | V8i, V8 XM | V8i, V8 XM | V8 XM | V8 XM |
| Version of .NET needed | 2.0 | 2.0 | 2.0 | 1.1 |
| Version | 10.03.00.01 |
| Date Released | 2020-Mar-03 |
| O/S compatibility | Windows 11, Windows 10, Windows 8/8.1, Windows 7, Windows Server 2012+ |
Each version of OpenRoads Designer, OpenSite Designer, and OpenRail Designer uses a different version of the OpenFlows technology (SewerGEMS/StormCAD). For model compatibility, see the table near the bottom of the following article: Understanding OpenFlows Hydraulics and Hydrology Functionality in Civil Products
| If you own this license | It will include these Storm-Sewer functions: | Subsurface Utility Engineering functionality |
NOTE: If you have SELECT OpenAccess licensing, you will have all the features above available for use.
Please note that the Standalone platform is always available and integration with a platform like AutoCAD, MicroStation or ArcGIS is not required. See : CAD Functionality in Standalone as an Alternative to AutoCAD or MicroStation Integration For example you can import MicroStation CAD files into the Standalone version using ModelBuilder and export the model plan view from Standalone to DXF format and insert that into your MicroStation design file.
Bentley's OpenFlows applications only integrate with full versions of AutoCAD and will not integrate with AutoCAD LT (Lite).
Note that versions of the OpenFlows products that are listed as being able to integrate up to ProjectWise CONNECT Edition will not integrate with ProjectWise 2023, 2024, etc.
ArcGIS Pro integration support started with WaterGEMS version 10.03.02.75
