WaterSight - Likelihood of failure
Product(s):WaterSight
Version(s):10.00.
Area:Documentation
The goal of this module is to help the user in the calculation of the likelihood of failure for each pipe, and with that identify the pipes that are more prone (or have higher probability) to fail in the future.
The calculation of the likelihood of failure for each pipe is based on some user defined criteria or aspects. As the aspects that can drive likelihood of failure, as well as the method to assess (or score) those aspects can vary significantly from utility to utility, from zone to zone, the solution offers a flexible and customizable workflow that can be adapted to any utility requirements.
How to start
1. Upload a pipe shapefile
Make sure that at least a pipe shapefile containing all the relevant information to be used in the Capital Planning has been uploaded, under Administration > GIS.
After that, and the very first time the user opens the LOF page, an empty page will be displayed with the following message: “No aspect Created, To create a new aspect go to [New].”
Note: In case you get an Error message instead, please check if the pipe shapefile contains at least a column named ID, as this is a minimum requirement.
Please make sure that your pipe shapefile contains all the relevant information, as this will be one of the sources for the capital planning analysis.
2. Append Model Results to Pipes Shapefile
It is also possible to include model results statistics calculated within WaterSight into the Capital Planning analysis. For this, just make sure that after uploading the pipe shapefile (and in case a hydraulic model is already uploaded and running) you click in the "append model results button" located inside the Admin >> GIS.
After defining the time period for which model results will be calculated and the mapping fields, automatically these results will be available inside the capital planning module. More information on appending model results, click here.
3. Upload other geospatial/contextual information
Other contextual or geospatial information may be relevant for the capital planning analysis. In this scope, the application allows to perform geospatial queries between the pipes shapes and other types of shapefiles such as proximity or intersection with streets, type of soils, water bodies, etc. The user can add any other relevant shapefile to be used in the capital planning, inside the Admin > GIS. More information about geospatial queries can be found here.
4. Creating Aspects
The first step involves the user defining which are the key criteria or aspects that can drive the likelihood of failure, taking into consideration both the data available as well the specific context of the utility and the region. Some common aspects amongst water utilities that can drive LOF can include:
These are just examples; the user can define any aspect that is considered relevant taking into consideration the data available, based on the original information provided in the pipe shapefile (see point 1 above), hydraulic model results (see point 2 above) or other contextual information (see point 3 above).
To start creating a new aspect, the user should click on the “New” button located in the top of the page:
There are two different ways how aspects can be created:
Decision Tree Aspect
Clicking on New > Decision Tree will redirect the user to a new page. To return back, the user can click on the back arrow located on the top. For more information about creating and scoring a Decision Tree aspect, please click here.
Predefined Aspect
When clicking on New > Predefined a pop-up dialog will appear to configure the predefined Aspect. To return back, the user can click on the close button (x) located on the top right of the po-up. For more information about creating and scoring a Predefined Aspect, please click here.
5. Analyzing Aspect Results
Once a new aspect is created (using the decision tree method or by creating a predefined one, see above), it will automatically be listed in the Likelihood of failure page, under the Aspects section.
Aspect Thumbnail tile
Each aspect created will have associated a small pie chart, with a quick indication of the number of pipes that fall in each LOF grade (default is red – high LOF, yellow – average LOF, green – low LOF), and, in the right side , the name defined by the user for the aspect and the method that was used (decision tree or predefined).
Aspect Summary Panel
By clicking in the aspects thumbnail tile, an aspect preview panel will be displayed on the right side, containing a mini-map with the pipes classified accordingly with the grades as well as an indication of the length of pipes that fall into each grade category.
Aspect Results Page
The user can click on “Open Results” from the summary panel (see above) to jump to the results page.
Another option is by clicking in the more button (…) inside the aspect thumbnail tile, that will be visible once hovering the tile. Click “Results” and a pop-up with several options will be displayed, including drilling into the results page.
6. Combining Different Aspects by Creating a Cumulative
After the key aspects are defined, and scores for each pipe and aspect are calculated (using Decision Tree or Predefined Method) the user needs to combine them together to build his multi-criteria decision ranking system. The multi-criteria decision ranking system is composed by the different key aspects (and scores) as well as the weight for each aspect. The final pipe score is obtained doing a weighted average of the individual pipe scores for each aspect.
To do this, the user should click in the New button located on the top of the page, and then choose the cumulative option.
Once clicking in the cumulative, the user will be redirected to the cumulative page where he will be able to define which aspects will be considered and the weights or importance for each one.
The software is flexible enough for the user to be able to include every key aspect in the same decision ranking system (mixing risk - likelihood and consequence of failure - with asset performance) or by creating a ranking system to separately assess likelihood of failure (LOF) and another ranking system to assess consequence of failure (COF). Then the user can combine both LOF and COF results to calculate the risk score using a risk matrix.
For more information on the cumulative, please click here.
7. Analyzing Cumulative Results
After a new cumulative is created, it will immediately get available in the Likelihood of Failure page, under the Cumulative section. Each cumulative that is created represents a LOF scenario, that takes into consideration all the relevant aspects defined by the user as well the relative importance of each one (as some aspects may be more important than others).
Cumulative Thumbnail tile
Each cumulative will have associated its own thumbnail tile, containing a mini map with the pipes classified according with the grades (on the left) as well as the name defined by the user and an indication of the length of pipes that fall into each grade category (on the right).
Cumulative Summary Panel
By clicking in the cumulative thumbnail tile, a summary preview will be displayed on the right side, containing a mini map with the pipes classified accordingly with the grades as well as an indication of the length of pipes that fall into each grade category as well as the aspects and weight contributing to the selected cumulative.
Cumulative Results Page
The user can click on “Open Results” from the summary panel (see above) to jump to the results page. Another option is by clicking in the more button (…) inside the cumulative thumbnail tile, that will be visible once hovering the tile. Click there and a pop-up with several options will be displaying, including drilling into the results page.
8. Comparing Different LOF Scenarios
The user can create until 6 cumulative (or LOF scenarios) at the same time to be displayed in the Likelihood of failure page. The main goal is for the user to easily understand how the Likelihood of failure can change when considering different aspects and/or different weights.
Configuring Grades
Clicking on the "Grade" button located on the top of the page will open a pop-up dialog for the user to configure the grades.
The user can configure:
Once the configuration of the grades is done, automatically all aspects and cumulative that were previously created are updated accordingly with the new grade definitions.
More Options
By hovering the cursor over each aspect or cumulative thumbnail tile, a more options button (…) will appear. Options available include:
Predefined Aspect
Prioritizing pipes
Aspect and Cumulative Results
Editing a Cumulative
Consequence of Failure
Risk Calculation
Planning
