Any fence report can be output in a 3-D view, and the site map can be displayed on the top and/or bottom of the 3-D viewing cube.
Any fence report can be viewed in 3-D, and rotated to view it from different angles. With a 3-D fence report you can visualize borehole positions in three dimensions. If a site map is present, you can also show the site map along the bottom, top, or both of the viewing cube. This enables you to see the borehole logs in the context of the site layout.
