Reports can show material graphic columns with interbedded layers.
A common natural phenomenon is to encounter layers composed of interbeds of two materials. Instead of creating many thin layers or designing symbols that represent every combination that might be encountered, you can specify that two material symbols are shown within a layer. The relative thicknesses of each material can also be specified as shown below.
