| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | N/A | ||
| Area: | Project Database | ||
| Subarea: | |||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
In Input, go to File>New Project. Select either Clone Data Template, Clone Project, or Clone from Current.
We recommend creating your projects by cloning from a data template. This ensures all your projects have the same structure. (Remember: to update your data template when you modify a project.)
Here is a short video that demonstrates how to do this: communities.bentley.com/.../269560.aspx
