Applies To | |||
Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
Version(s): | N/A | ||
Environment: | N/A | ||
Area: | Project Database | ||
Subarea: | |||
Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
This short video, communities.bentley.com/.../269619.aspx, will show you how to create a lookup list that can be assigned to a field in your project. A library table can be used for the same purpose.
