| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | N/A | ||
| Area: | Symbol Design | ||
| Subarea: | |||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
How do I create a printout or PDF of all the material, sample and/or well symbols in our library?
In the Available Objects list, select Material Composite Symbols and/or Sampler Composite Symbols and/or Well Composite Symbols.
Click the > button to move your selection to the Objects to Print list.
To print click the Execute button.
To export to PDF, gINT drawing (*.GDW), DXF, Bitmap, etc., click the Export to button, enter a file name and click Save. Click Execute.
