Applies To | |||
Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
Version(s): | |||
Environment: | N\A | ||
Area: | Export Data | ||
Subarea: | N\A | ||
Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
7 Out of memory===gInt8a
Sometimes in Excel, you can have rows that appear empty but have nulls or spaces. If there are too many of these rows importing to gINT will fail.
To see if this is the problem, open the Excel file. Click Ctrl+End on your keyboard. This will move the cursor to the last row with data. If the cursor goes to an empty row, then it contains either nulls or spaces. If it is a few thousand rows below your data this is the problem.
To fix this:
