| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | 08.30.03.135 | ||
| Area: | Import Data | ||
| Subarea: | N\A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
Import stops at 100% and doesn't finish in gINT 08.30.03.135.
There is a temporary file that is created during the import that is deleted when the import finishes. This problem will occur if the user does not have permission to delete in the folder where the temporary file is saved.
This problem will go away on upgrading gINT to a newer build.
Another way to solve this is to give the user administrator rights on their computer.
