| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | 08.30.03.135 | ||
| Area: | Data Entry | ||
| Subarea: | N/A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
gINT is crashing each time the "Field Properties" window loses focus with this message:
Run-time error '0'
To produce:
The field properties window has disappeared behind the gINT program. It can't be moved, minimized or resized to get at it nor can Alt+Tab be used to access the window.
Clicking on "show desktop" or entering the key board short cut "Win+D" and then clicking on gINT in the task bar will return to the "Field properties" dialog, but gINT then crashes with the error message above.
This problem has been fixed in gINT version 8.30.03.186.
