These files contain fully-functional applications designed to runĀ inside gINT. They include specialty reports, database structures, and gINT Rules that perform calculations and data validation. Where an application produces reports other than logs, gINT Professional or gINT Professional Plus is required for full functionality.
While we have worked to ensure these templates are current and produce correct results, we make no warranty of suitability or correctness. These files are provided at no charge and they are to be taken as-is.
You are free to modify these files.
Application |
Preview reports (PDF) |
Download (Zip) [[Using gINT Downloaded Examples|File Contents]] |
Last Update |
CBR Test (California Bearing Ratio) |
cbr_test.zip |
12 Sep 2005 | |
Concrete Testing |
concrete_test.zip |
2 Feb 2012 |
